跳转到主内容
Nikon Coolpix A900 Monitor Replacement
Andres Aronstam
Andres Aronstam 另一个贡献者
最后更新于 June 16, 2020
5分钟
中等
This guide will show you how to remove the monitor assembly on the Nikon Coolpix A900.
If the monitor on your camera suffers a hard drop, water damage, or gets to scratched up, you may want to replace your monitor.
This guide is relatively simple, but be sure to have a container for small parts ready.
你所需要的
工具
查看更多...
  1. Nikon Coolpix A900 Monitor Replacement, Battery: 步骤 1 中的图像 1,1
    • Orient the camera so that it is upside down, with the lens facing towards you.
  2. Nikon Coolpix A900 Monitor Replacement: 步骤 2 中的图像 1,2 Nikon Coolpix A900 Monitor Replacement: 步骤 2 中的图像 2,2
    • Slide the battery door lock left to unlock it.
    • The battery door will automatically open.
    Good addition of different conditions of the camera (camera is dirty)
    Brandon - 回复
  3. Nikon Coolpix A900 Monitor Replacement: 步骤 3 中的图像 1,2 Nikon Coolpix A900 Monitor Replacement: 步骤 3 中的图像 2,2
    • Slide the yellow tab up to release the battery.
    • To re-insert a battery, slide the battery back in until the yellow tab locks it in place.
    • There is a diagram on the opposite side of the battery compartment to help you orient the battery correctly.
  4. Nikon Coolpix A900 Monitor Replacement, Rear Case: 步骤 4 中的图像 1,3 Nikon Coolpix A900 Monitor Replacement, Rear Case: 步骤 4 中的图像 2,3 Nikon Coolpix A900 Monitor Replacement, Rear Case: 步骤 4 中的图像 3,3
    • Orient the camera upside down, with the lens facing away from you.
    • Remove the two 3mm Phillips #00 screws from the right.
    • Remove the two 3.4mm Phillips #00 screws from the left.
  5. Nikon Coolpix A900 Monitor Replacement: 步骤 5 中的图像 1,3 Nikon Coolpix A900 Monitor Replacement: 步骤 5 中的图像 2,3 Nikon Coolpix A900 Monitor Replacement: 步骤 5 中的图像 3,3
    • Turn the camera on its side, with the lens facing away from you.
    • Remove the 3.4mm Phillips #00 screw. Repeat this for the opposite side of the camera.
  6. Nikon Coolpix A900 Monitor Replacement: 步骤 6 中的图像 1,3 Nikon Coolpix A900 Monitor Replacement: 步骤 6 中的图像 2,3 Nikon Coolpix A900 Monitor Replacement: 步骤 6 中的图像 3,3
    • Place the camera upright with the lens facing away from you.
    • Move the monitor down, and remove two 4.4 mm screws.
    After dropping the camera image with small apertures appears
    D.Osei - 回复
  7. Nikon Coolpix A900 Monitor Replacement: 步骤 7 中的图像 1,2 Nikon Coolpix A900 Monitor Replacement: 步骤 7 中的图像 2,2
    • Remove the two black 2.5 mm screws from the monitor bracket.
    Is there anywhere I can buy a replacement screw for this part? I have lost one of these screws
    Dylan Feeney - 回复
  8. Nikon Coolpix A900 Monitor Replacement: 步骤 8 中的图像 1,2 Nikon Coolpix A900 Monitor Replacement: 步骤 8 中的图像 2,2
    • Return the monitor to the closed position.
    • Gently open the rear case.
    • You may need opening tools to help separate the rear case.
    • Be careful when opening the rear case to not damage the ribbon connectors.
  9. Nikon Coolpix A900 Monitor Replacement: 步骤 9 中的图像 1,3 Nikon Coolpix A900 Monitor Replacement: 步骤 9 中的图像 2,3 Nikon Coolpix A900 Monitor Replacement: 步骤 9 中的图像 3,3
    • Place the camera lens down, while supporting the rear case.
    • Unlock the two ribbons by using your finger to lift the plastic hinge on the ribbon connector.
    • With the ribbons disconnected, you can now remove the rear case.
  10. Nikon Coolpix A900 Monitor Replacement, Monitor: 步骤 10 中的图像 1,3 Nikon Coolpix A900 Monitor Replacement, Monitor: 步骤 10 中的图像 2,3 Nikon Coolpix A900 Monitor Replacement, Monitor: 步骤 10 中的图像 3,3
    • Set the rear case screen down.
    • Remove the two 2.5 mm black Phillips #00 screws.
  11. Nikon Coolpix A900 Monitor Replacement: 步骤 11 中的图像 1,2 Nikon Coolpix A900 Monitor Replacement: 步骤 11 中的图像 2,2
    • Separate the rear case from the monitor assembly.
    • Make sure that the ribbon cable does not snag on the rear case when removing it.
    Hello. Excellent help. Where can I get a new screen for my Nikon A900 when the screen glass is broken and the screen is not clear, please?
    Timo Nieminen - 回复
结论
4指南评论
Where did you get a new monitor for your camera?
photower - 回复
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
Laurent Farrugia - 回复
This is excellent but where would you get a new 3” monitor?
Panders McMulluon - 回复
Have you tried AliExpress or Ebay?
photower -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 46
总计 1,299
