Nikon Coolpix A900 Monitor Replacement
简介
转到步骤 1This guide will show you how to remove the monitor assembly on the Nikon Coolpix A900.
If the monitor on your camera suffers a hard drop, water damage, or gets to scratched up, you may want to replace your monitor.
This guide is relatively simple, but be sure to have a container for small parts ready.
Orient the camera upside down, with the lens facing away from you.
Remove the two 3mm Phillips #00 screws from the right.
Remove the two 3.4mm Phillips #00 screws from the left.
Remove the two black 2.5 mm screws from the monitor bracket.
Is there anywhere I can buy a replacement screw for this part? I have lost one of these screws
Separate the rear case from the monitor assembly.
Hello. Excellent help. Where can I get a new screen for my Nikon A900 when the screen glass is broken and the screen is not clear, please?
4指南评论
Bonjour superbe étape par étape ou puis je trouver l’écran LCD du NIKON A900 je ne le trouve pas ! merci de votre retour !
et un grand merci à des personnes comme vous qui nous aide nous pauvre novice !!!
This is excellent but where would you get a new 3” monitor?
Have you tried AliExpress or Ebay?
photower -
