跳转到主内容
Huawei Mate 10 Pro Screen and Digitizer Replacement
Dominik Schnabelrauch
Dominik Schnabelrauch3 其他贡献者
最后更新于 March 9, 2023
1 - 2 小时
困难
Use this guide to replace the screen and digitizer in your Huawei Mate 10 Pro.
Opening the Mate 10 Pro will damage the waterproof sealing on the device. If you do not replace the adhesive seals, your phone will function normally, but will loose its water-protection.
Before disassembling your phone, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
你所需要的
配件
工具
查看更多...
  1. Huawei Mate 10 Pro Screen and Digitizer Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Switch off your phone.
    • Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
  2. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 2 中的图像 1,3 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 2 中的图像 2,3 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Halberd Spudger
    $2.99
    • Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
    • Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
    • Use opening picks to avoid the adhesive from sticking to the back cover again while cutting the adhesive on all sides.
  3. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 3 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 3 中的图像 2,2
    • Don't remove the back cover all the way, yet. The fingerprint sensor cable is still connected to motherboard.
    • Flip the back cover over to the side.
    • Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
  4. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 4 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
    • Disconnect the fingerprint sensor cable with a spudger.
    • When reassembling your phone apply new adhesive where it is necessary.
  5. Huawei Mate 10 Pro Screen and Digitizer Replacement, Shields: 步骤 5 中的图像 1,3 Huawei Mate 10 Pro Screen and Digitizer Replacement, Shields: 步骤 5 中的图像 2,3 Huawei Mate 10 Pro Screen and Digitizer Replacement, Shields: 步骤 5 中的图像 3,3
    • Remove the twelve Phillips #00 screws.
    • Carefully remove the shields on top of the motherboard and the charging board.
    • In case the shields do not pop out easily on their own after you removed the Phillips screws, you can use the pointed end of a spudger to pry them out.
  6. Huawei Mate 10 Pro Screen and Digitizer Replacement, Charging Port: 步骤 6 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement, Charging Port: 步骤 6 中的图像 2,2
    • Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
  7. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 7 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers to carefully remove the charging port including its flex cable.
    • The charging port sits tightly in its recess. In case you have trouble removing it, use the flat end of a halberd spudger to pry it out.
  8. Huawei Mate 10 Pro Screen and Digitizer Replacement, Battery: 步骤 8 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement, Battery: 步骤 8 中的图像 2,2
    • Use a spudger to disconnect the battery flex cable.
    • Apply an iOpener on the screen for at least one minute to loosen the adhesive beneath the battery.
  9. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 9 中的图像 1,3 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 9 中的图像 2,3 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 9 中的图像 3,3
    • The display flex cable runs underneath the battery. So be careful not do damage it when loosening the adhesive. Also take care not to bend or puncture the battery at any time.
    • Use a spudger to carefully pry up the battery and slide along the side to separate the adhesive.
    • Remove the battery.
    • When reassembling your phone replace the old adhesive with double-sided tape or pre-cut adhesive.
  10. Huawei Mate 10 Pro Screen and Digitizer Replacement, Screen and Digitizer: 步骤 10 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement, Screen and Digitizer: 步骤 10 中的图像 2,2
    • Use a spudger to disconnect the display flex cable.
    • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive underneath. Especially take care of the upper and lower part.
    • If your display is broken or cracked protect your eyes from glass shreds apply some clear tape onto the screen to also get a better grip to open the phone.
    • The display of the Huawei Mate 10 Pro is extremely sticky and you might need to repeat this process during the display removal.
  11. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 11 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 11 中的图像 2,2
    • If your display isn't already broken, it is likely to break during this process. You might want to protect your hands and eyes from glass shards.
    • Push a spudger against the back of the display through the cutout in the midframe, where the charging port was located, to create a gap between the display and the frame.
    • The adhesive is really sticky so this can be a lengthy and difficult procedure. Take care not to damage any other components while doing so.
    • Insert the tip of an opening pick into the gap you just created.
  12. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 12 中的图像 1,2 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 12 中的图像 2,2
    • Use the opening pick to cut the adhesive around all sides of the Huawei Mate 10 pro.
    • Be careful at the top around the front camera. Only insert the very tip of the opening pick to avoid damaging the camera.
    • In case you're having trouble to cut the adhesive, you can re-use the iOpener to loosen the adhesive again.
  13. Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 13 中的图像 1,3 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 13 中的图像 2,3 Huawei Mate 10 Pro Screen and Digitizer Replacement: 步骤 13 中的图像 3,3
    • After cutting the adhesive on all sides of the phone, flip the opening pick to lift up the display.
    • It's possible that the display cable still sticks a little to the mid frame. In this case loosen it carefully and thread it through the gap in the frame.
    • Remove the display.
    • Remove any remaining adhesive from the phone, and clean the glued areas with >90% isopropyl alcohol and a lint-free cloth.
结论
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
20等其他人完成本指南。
于11/23/16注册
232,321 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,866篇指南
3指南评论
Nicely written guide, I am curious about trying this myself in the near future. I have sadly got a tiny scratch in my screen in the last couple days where I haven’t had a screen protector on! Very frustrating.
I’ve replaced almost everything for an iPhone 6+ and done a complete teardown. How difficult is this repair compared to something like that?
Ed Davidson-Bowman - 回复
Perfect tutorial, my only problem was doing it without an opener was difficult. I don’t know if this kind of comment is allowed, and it it isn’t, please just edit this part instead of taking down the whole comment. An icepack in the microwave worked VERY well for me in the end.
That said, breaking the screen to take it off was VERY hurtful in my soul.
Thanks for the instructions!!!
Alex Vermillion - 回复
Tried this, on the Mate10 PRO with already broken screen
the most difficult part was the Battery Adhesive that was strong.
By the way using hair dryer I get it slowly appart.
After that all went smooth but after putting the new screen (that works well) I have no touch with it, so I can't unlock the phone, stop an alarm, slide anything
Did I miss something ?
Johann G. - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 28
过去 30 天: 140
总计 29,379
