跳转到主内容
How to open the Huawei Watch GT 3 (46mm) for Repairs
Dominik Schnabelrauch
最后更新于 September 19, 2024
10 - 20 分钟
中等
Use this guide to open your Huawei Watch GT 3 (46 mm) for repairs.
你所需要的
工具
  • T2 Torx Screwdriver
    T2 Torx Screwdriver
  • Spudger
    Spudger
查看更多...
  1. How to open the Huawei Watch GT 3 (46mm) for Repairs, Remove the watch band: 步骤 1 中的图像 1,1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to open the Huawei Watch GT 3 (46mm) for Repairs, Unfasten the back cover screws: 步骤 2 中的图像 1,1
    • Remove the four 3.7 mm-long Torx T2 screws securing the back cover.
  3. How to open the Huawei Watch GT 3 (46mm) for Repairs, Pry up the rear panel: 步骤 3 中的图像 1,2 How to open the Huawei Watch GT 3 (46mm) for Repairs, Pry up the rear panel: 步骤 3 中的图像 2,2
    • Insert the edge of a spudger into the the loudspeaker opening at the bottom edge of your watch.
    • When prying up the back cover put a finger on top or the edge of it and hold it down. Too much force during the prying procedure may lead to popping off the back cover too quickly and tearing the rear panel assembly cable.
    • The plastic clamps holding the back cover in place sit very tight and may require some force during the prying procedure.
    • Use a spudger to pry up the rear panel of your Huawei watch GT 3.
    • Don't try to remove the back cover assembly all the way yet, it's still connected to the daughterboard.
  4. How to open the Huawei Watch GT 3 (46mm) for Repairs, Swing open the rear panel assembly: 步骤 4 中的图像 1,2 How to open the Huawei Watch GT 3 (46mm) for Repairs, Swing open the rear panel assembly: 步骤 4 中的图像 2,2
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
2等其他人完成本指南。
于11/23/16注册
231,292 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
121 名成员
创作了19,669篇指南
1指南评论
I am curious to see why the altimeter on my Huawei Smartwatch GT3 stopped working and got stuck at zero reading. That happened right after the last HarmonyOS back in June 2024.
So, I'm not sure if it was a software issue that needed fixing or actual hardware? Any though back?
Joe - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 52
过去 30 天: 257
总计 4,412
