此翻译由机器生成,尚未经过人工审核。 会说这种语言吗? 查看评论。
简介
本维修指南由 iFixit 员工撰写,未经 Google 官方认可。 了解更多关于我们维修指南的信息,请点击此处。
本指南将教你如何更换 Google Pixel XL 的后置摄像头。请按照本指南更换 Google Pixel XL 的后置摄像头模块。
Pixel XL 的非增强显示面板十分脆弱,且通过强力胶水固定在中框上,这使得维修难度较大。折断显示屏的风险很高,特别是当它已经有细微裂纹时。请务必充分加热,并在撬动过程中极其小心。后置摄像头位于设备的主板上。
你所需要的
加热iOpener并将其覆盖在显示屏的上边缘两分钟。
在开始撬动屏幕前注意以下区域:
显示面板边缘的细条粘合剂
厚粘合剂
容易损坏的OLED显示面板
撬动过程中可能会受损的显示屏排线
抓住主板的边角将其从凹槽中移出,注意不要挂到任何线缆。
稍微弯曲指纹传感器电缆,使其在连接器附近向上拱起。
将主板竖起并调整位置,使连接器靠在插孔上。
用手指仔细对齐连接器并将其按压进插孔。 切勿用力过猛! 如果操作正确,插孔应能稳固地固定住连接器。
要重新组装设备,请按相反顺序执行这些说明。
维修过程没有按计划进行?请查看我们的 Google Pixel XL Answers 社区以寻求故障排除帮助。
6等其他人完成本指南。
5指南评论
https://www.witrigs.com/oem-rear-camera-...
This is one of other only places I could find to get a replacement camera module.
iFixit sells the replacement part here. It looks like new camera modules are out of stock, but used and fully tested ones are still in stock as of May 15, 2018.
A helpful tip: before you re-assemble the phone, shine a bright light through the back glass and check that there is no dust or debris on the inside of the back glass or the camera lens.
Also, this may be obvious to some, but you will need replacement adhesive for the display in order to re-attach it to the phone. I didn’t even think about this until I had already started the repair and taken the display off.
Do you think that if I put a Pixel 3 camera in there, it would still work?
Have any of you tried to up the storage capacity on one of these things?
Jeremy Sing - 回复 分享
