跳转到主内容
加入维修社区 - 创建账户
Google Pixel XL Fingerprint Sensor Replacement
你所需要的
  1. Google Pixel XL Fingerprint Sensor Replacement, SIM Card Tray: 步骤 1 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement, SIM Card Tray: 步骤 1 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement, SIM Card Tray: 步骤 1 中的图像 3,3
    • Insert a SIM eject tool, SIM eject bit, or a paperclip into the small hole on the left edge of the phone, near the top.
    • Press to eject the tray.
    询问修复机器人
    添加评论
  2. Google Pixel XL Fingerprint Sensor Replacement, Display Assembly: 步骤 2 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement, Display Assembly: 步骤 2 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement, Display Assembly: 步骤 2 中的图像 3,3
    • Heat an iOpener and apply it to the top edge of the display for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • Take note of the following regions before you begin prying:
    • Thin adhesive lined against the display panel
    • Thick adhesive
    • The OLED display panel, which is very prone to damage
    • The display cable, which can be damaged during prying
    添加评论
  3. Google Pixel XL Fingerprint Sensor Replacement: 步骤 3 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 3 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 3 中的图像 3,3
    • Once the edge is warm to the touch, apply a suction cup close to the edge.
    • Lift on the suction cup, and insert an opening pick into the gap.
    • Do not insert the pick more than 13 mm (0.5 inches), or you will damage the display assembly.
    • If you have trouble creating a gap, reheat the edge and try again.
    • You can also try to use a playing card instead of an opening pick to help make the initial entry.
    添加评论
  4. Google Pixel XL Fingerprint Sensor Replacement: 步骤 4 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 4 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 4 中的图像 3,3
    • Slide the opening clip across the top edge to slice through the adhesive.
    • Be sure not to cut deeper than 13 mm (0.5 inches) or you will damage the display.
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Leave an opening pick in the edge to prevent the adhesive from resealing.
    询问修复机器人
    添加评论
  5. Google Pixel XL Fingerprint Sensor Replacement: 步骤 5 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 5 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 5 中的图像 3,3
    • Heat an iOpener and apply it to the right edge of the phone for two minutes.
    • Insert an opening pick near the top edge of the phone, where you have already sliced the adhesive.
    • Slowly guide the pick around the right corner.
    • Carefully slide the pick down the right edge of the phone to slice through the adhesive.
    • Do not insert the pick more than 1 mm (1/32") along the edge, or you will damage the display assembly.
    • Repeat the step for the left edge of the phone.
    询问修复机器人
    添加评论
  6. Google Pixel XL Fingerprint Sensor Replacement: 步骤 6 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 6 中的图像 2,2
    • Heat the bottom edge with an iOpener for two minutes.
    • Insert a pick near the right edge where you have already loosened the adhesive.
    • Carefully guide the pick around the corner.
    • Slide the pick along the bottom edge to slice through the adhesive.
    • Do not slice deeper than 8.5 mm (1/3") or you will damage the display cable.
    询问修复机器人
    添加评论
  7. Google Pixel XL Fingerprint Sensor Replacement: 步骤 7 中的图像 1,1
    • Once you have sliced around the perimeter of the phone, carefully lift the display assembly up slightly by the right corners.
    • Do not attempt to remove the display assembly. It is still attached by a flex cable.
    • Use an opening pick to slice through any remaining adhesive.
    添加评论
  8. Google Pixel XL Fingerprint Sensor Replacement: 步骤 8 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 8 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 8 中的图像 3,3
    • Lift the display assembly from the top end and swing it around such that it rests upside down on the frame.
    • Be careful not to strain the flex cable when you swing the assembly around.
    询问修复机器人
    添加评论
  9. Google Pixel XL Fingerprint Sensor Replacement: 步骤 9 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 9 中的图像 2,2
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Remove the two 4 mm T5 screws securing the display cable bracket.
    • Remove the display cable bracket.
    询问修复机器人
    添加评论
  10. Google Pixel XL Fingerprint Sensor Replacement: 步骤 10 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 10 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the display cable from its connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    添加评论
  11. Google Pixel XL Fingerprint Sensor Replacement: 步骤 11 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 11 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 11 中的图像 3,3
    在这个步骤中使用的工具:
    • Remove the display assembly.
    • For comprehensive instructions on how to reinstall the Pixel XL display, follow this guide.
    • If your replacement display did not come with a speaker grille, use tweezers to gently peel the adhesive grille from your old display, and transfer it to the replacement.
    • Before installing a new display, be sure to remove all traces of adhesive from the frame. Use a spudger or an opening tool to scrape it off, and use high-concentration isopropyl alcohol to remove any residue.
    • If you are reinstalling the same display assembly, be sure to remove all adhesive residue from the panel and the frame before applying new adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
    添加评论
  12. Google Pixel XL Fingerprint Sensor Replacement, Google Pixel XL Opening Procedure: 步骤 12 中的图像 1,1
    • Remove the following screws that secure the midframe to the back:
    • Seven black 4 mm T5 screws
    • Two silver 3 mm T5 screws
    询问修复机器人
    添加评论
  13. Google Pixel XL Fingerprint Sensor Replacement: 步骤 13 中的图像 1,1
    • The midframe is held tightly in place by plastic clips which push into the edge of the back case.
    询问修复机器人
    添加评论
  14. Google Pixel XL Fingerprint Sensor Replacement: 步骤 14 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 14 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 14 中的图像 3,3
    • Find the small notch in the bottom left corner of the frame and insert an opening pick.
    • Slide the opening pick along the bottom edge of the phone towards the bottom right corner and leave it there.
    添加评论
  15. Google Pixel XL Fingerprint Sensor Replacement: 步骤 15 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 15 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 15 中的图像 3,3
    • Insert a separate opening pick into the right edge of the phone, near the bottom.
    • Slowly push the pick upwards along the seam until the first clip pops free.
    • Due to the tight tolerances, this may be difficult, requiring a substantial amount of force. If you are having trouble, try inserting and sliding a playing card.
    • Once you've released the clip, leave the opening pick in place to prevent the midframe from resealing.
    添加评论
  16. Google Pixel XL Fingerprint Sensor Replacement: 步骤 16 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 16 中的图像 2,2
    • Insert an opening pick into the right edge of the phone and slide it upwards towards the top right clip.
    • You do not need to insert the pick more than 2 mm into the edge. If you insert the pick all the way in, you may risk damaging flex cables.
    • Slowly slide the pick past the clip to disengage it from the frame.
    • At this point, the right edge of the midframe should be free from the case. If it isn't, slide an opening clip up and down along the right edge.
    询问修复机器人
    添加评论
  17. Google Pixel XL Fingerprint Sensor Replacement: 步骤 17 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 17 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 17 中的图像 3,3
    • Grasp the right edge of the midframe by the corners and slowly hinge the edge up.
    • When the left edge feels loose, stop hinging and lift the midframe upwards.
    • Remove the midframe.
    • To reinstall the midframe, align it to the case, then squeeze around the perimeter until all the clips snap back into position. When properly done, the midframe should lie flat.
    添加评论
  18. Google Pixel XL Fingerprint Sensor Replacement, Motherboard: 步骤 18 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement, Motherboard: 步骤 18 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement, Motherboard: 步骤 18 中的图像 3,3
    • Use the point of a spudger to pry up and disconnect the battery connector.
    • Bend the battery flex cable slightly so that it will not accidentally touch the motherboard.
    询问修复机器人
    添加评论
  19. Google Pixel XL Fingerprint Sensor Replacement: 步骤 19 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 19 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the button strip connector.
    • If the button strip's metal clip falls out during the repair, align the clip and push it back into its groove.
    询问修复机器人
    添加评论
  20. Google Pixel XL Fingerprint Sensor Replacement: 步骤 20 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 20 中的图像 2,2
    在这个步骤中使用的工具:
    • Use tweezers to peel up the tape at the top of the interconnect cable.
    询问修复机器人
    添加评论
  21. Google Pixel XL Fingerprint Sensor Replacement: 步骤 21 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 21 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from the motherboard.
    询问修复机器人
    添加评论
  22. Google Pixel XL Fingerprint Sensor Replacement: 步骤 22 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 22 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 22 中的图像 3,3
    • Use the point of a spudger to disconnect the black antenna cable from the motherboard, near the front facing camera module.
    • Route the antenna cable out of its retaining clip.
    询问修复机器人
    添加评论
  23. Google Pixel XL Fingerprint Sensor Replacement: 步骤 23 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 23 中的图像 2,2
    • Use the point of a spudger to pry up and disconnect the white antenna cable from the motherboard, near the rear facing camera module.
    添加评论
  24. Google Pixel XL Fingerprint Sensor Replacement: 步骤 24 中的图像 1,1
    • Remove the two 3 mm T5 screws securing the motherboard to the frame.
    • During reinstallation, be sure that both camera modules and the headphone jack module are seated properly in their sockets before screwing down the motherboard.
    询问修复机器人
    添加评论
  25. Google Pixel XL Fingerprint Sensor Replacement: 步骤 25 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 25 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 25 中的图像 3,3
    • Use the point of a spudger to pry up and loosen the front facing camera module from its socket.
    询问修复机器人
    添加评论
  26. Google Pixel XL Fingerprint Sensor Replacement: 步骤 26 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 26 中的图像 2,2
    • Insert the point of a spudger into the headphone jack port and pry upwards to loosen the port from its socket.
    询问修复机器人
    添加评论
  27. Google Pixel XL Fingerprint Sensor Replacement: 步骤 27 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 27 中的图像 2,2
    • Be sure that you have ejected the SIM card tray before performing this step.
    • Use the flat end of a spudger to pry the bottom edge of the motherboard up slightly, loosening it from its recess.
    • Do not try to remove the motherboard yet. It is still connected by a flex cable.
    询问修复机器人
    添加评论
  28. Google Pixel XL Fingerprint Sensor Replacement: 步骤 28 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 28 中的图像 2,2
    • Locate the fingerprint sensor cable attached to the underside of the motherboard, near the bottom edge.
    • Use the point of a spudger to pry and release the fingerprint sensor cable from its socket.
    • Peel the cable away from the motherboard.
    询问修复机器人
    添加评论
  29. Google Pixel XL Fingerprint Sensor Replacement: 步骤 29 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement: 步骤 29 中的图像 2,2
    询问修复机器人
    添加评论
  30. Google Pixel XL Fingerprint Sensor Replacement, Fingerprint Scanner: 步骤 30 中的图像 1,2 Google Pixel XL Fingerprint Sensor Replacement, Fingerprint Scanner: 步骤 30 中的图像 2,2
    • Position your thumb over the fingerprint sensor and push firmly until the sensor pops out of its indention.
    询问修复机器人
    添加评论
  31. Google Pixel XL Fingerprint Sensor Replacement: 步骤 31 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 31 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 31 中的图像 3,3
    • Remove the fingerprint sensor.
    • To reinstall the fingerprint sensor, it is easier to attach it to the motherboard first before positioning it in its indentation.
    • Align the fingerprint sensor's connector to the motherboard socket, which is located on the underside near the battery edge.
    • Use your finger to press the connector into the socket. Do not use excessive force! The connector should click into position if done correctly.
    询问修复机器人
    添加评论
  32. Google Pixel XL Fingerprint Sensor Replacement: 步骤 32 中的图像 1,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 32 中的图像 2,3 Google Pixel XL Fingerprint Sensor Replacement: 步骤 32 中的图像 3,3
    • Move the motherboard into position near its recess.
    • Use your finger to press the fingerprint sensor down into its indentation.
    • Be sure that the sensor is properly aligned in the indentation.
    • Continue with the reassembly.
    询问修复机器人
    添加评论
结论
Repair didn’t go as planned? Check out our Google Pixel XL Answers community for troubleshooting help.
取消:我没有完成这个指南。
6等其他人完成本指南。
Arthur Shi
于01/03/18注册
344,126 声望
创作了915篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 52
总计 3,739
