跳转到主内容
加入维修社区 - 创建账户
Google Pixel 6 Loudspeaker Replacement
你所需要的
  1. Google Pixel 6 Loudspeaker Replacement, Safety precautions: 步骤 1 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement, Safety precautions: 步骤 1 中的图像 2,2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 6 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 2 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 2 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement, Anti-Clamp instructions: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Loudspeaker Replacement: 步骤 3 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 3 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 3 中的图像 3,3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Loudspeaker Replacement: 步骤 4 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 4 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 4 中的图像 3,3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Loudspeaker Replacement, Loosen the display adhesive: 步骤 5 中的图像 1,1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. Google Pixel 6 Loudspeaker Replacement, Insert an opening pick: 步骤 6 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement, Insert an opening pick: 步骤 6 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement, Insert an opening pick: 步骤 6 中的图像 3,3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Loudspeaker Replacement, Slice the adhesive: 步骤 7 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement, Slice the adhesive: 步骤 7 中的图像 2,2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  8. Google Pixel 6 Loudspeaker Replacement: 步骤 8 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 8 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 8 中的图像 3,3
    • The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Loudspeaker Replacement: 步骤 9 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 9 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 9 中的图像 3,3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Loudspeaker Replacement: 步骤 10 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement: 步骤 10 中的图像 2,2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Loudspeaker Replacement, Open up the phone assembly: 步骤 11 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement, Open up the phone assembly: 步骤 11 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement, Open up the phone assembly: 步骤 11 中的图像 3,3
    • Avoid straining the display cable during the following procedure.
    • Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
  12. Google Pixel 6 Loudspeaker Replacement, Remove the display cable bracket: 步骤 12 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement, Remove the display cable bracket: 步骤 12 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement, Remove the display cable bracket: 步骤 12 中的图像 3,3
    在这个步骤中使用的工具:
    • Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  13. Google Pixel 6 Loudspeaker Replacement, Disconnect the display cable: 步骤 13 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement, Disconnect the display cable: 步骤 13 中的图像 2,2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  14. Google Pixel 6 Loudspeaker Replacement, Screen information: 步骤 14 中的图像 1,1
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
  15. Google Pixel 6 Loudspeaker Replacement, Remove the screen: 步骤 15 中的图像 1,1
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
  16. Google Pixel 6 Loudspeaker Replacement, Loosen the graphite film adhesive: 步骤 16 中的图像 1,1
    • Apply a heated iOpener or a heat gun to the rear glass to loosen the adhesive underneath the graphite films on top of the battery. Apply the iOpener for at least two minutes.
    • Don't apply heat directly onto the battery. It is susceptible to heat damage and could cause a thermal event.
  17. Google Pixel 6 Loudspeaker Replacement, Remove the graphite films: 步骤 17 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement, Remove the graphite films: 步骤 17 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement, Remove the graphite films: 步骤 17 中的图像 3,3
    在这个步骤中使用的工具:
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the top edge of the battery and the motherboard shield.
    • Remove the graphite film.
  18. Google Pixel 6 Loudspeaker Replacement: 步骤 18 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 18 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 18 中的图像 3,3
    • If the graphite film is hard to peel off, it has most likely cooled down. Reapply your iOpener or heat gun to the rear glass for 1-2 minutes to reheat it.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the left edge of the battery and the motherboard shield.
  19. Google Pixel 6 Loudspeaker Replacement: 步骤 19 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 19 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 19 中的图像 3,3
    • The graphite film at the bottom edge of the battery only needs to be removed when replacing the battery or the loudspeaker.
    • Use a pair of blunt nose tweezers or a clean fingernail to carefully peel the black graphite film off the bottom edge of the battery and the loudspeaker assembly.
    • You'll also remove a piece of foam that bridges the display and the speaker. Be sure to replace the foam after installing a new graphite film.
  20. Google Pixel 6 Loudspeaker Replacement, Unfasten the motherboard cover screws: 步骤 20 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • Use a Torx T3 screwdriver to remove the screws securing the motherboard cover:
    • Eight 4.8 mm-long screws
    • One 2.4 mm-long screw
  21. Google Pixel 6 Loudspeaker Replacement: 步骤 21 中的图像 1,3 Google Pixel 6 Loudspeaker Replacement: 步骤 21 中的图像 2,3 Google Pixel 6 Loudspeaker Replacement: 步骤 21 中的图像 3,3
    • Carefully lift up the motherboard cover and remove it.
  22. Google Pixel 6 Loudspeaker Replacement, Disconnect the battery cable: 步骤 22 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement, Disconnect the battery cable: 步骤 22 中的图像 2,2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  23. Google Pixel 6 Loudspeaker Replacement, Unfasten the loudspeaker screws: 步骤 23 中的图像 1,1
    • Use a Torx T3 screwdriver to remove the five 4.8 mm-long screws securing the loudspeaker.
  24. Google Pixel 6 Loudspeaker Replacement, Pry up the loudspeaker: 步骤 24 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement, Pry up the loudspeaker: 步骤 24 中的图像 2,2
    • Insert an opening pick into the gap between the bottom edge of the battery and the loudspeaker.
    • Use the opening pick to pry up the loudspeaker by tilting it downwards.
  25. Google Pixel 6 Loudspeaker Replacement, Remove the loudspeaker: 步骤 25 中的图像 1,2 Google Pixel 6 Loudspeaker Replacement, Remove the loudspeaker: 步骤 25 中的图像 2,2
    在这个步骤中使用的工具:
    • Use a pair of tweezers or your fingers to remove the loudspeaker.
    • Compare your new replacement part to the original part—you may need to transfer remaining components like the protective foam cushions.
结论
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
另外一个人完成了本指南。
Dominik Schnabelrauch
于11/23/16注册
255,315 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
124 名成员
创作了25,165篇指南
2指南评论
Ein Foto der Unterseite des Ersatzteils wäre sehr hilfreich! Ich frage mich, wie der Lautsprecher verbunden ist und ob er bei mir nur verrutscht ist, da er funktioniert solange ich das Gerät seitlich quetsche...
Jedes Öffnen des Geräts birgt leider die Gefahr, das OLED von hinten beim Wiederzusammenbau zu punktieren, über die bescheuerten kleinen Antennen, deswegen benutze ich jetzt erstmal Bluetooth Lautsprecher.
Andi - 回复 分享
This fix worked perfectly for me! I didn't have prior experience doing phone repair work, so this is definitely beginner accessible if you are careful. Instructions were good, but the parts list should also include the battery graphite tape, since you will need to remove all three graphite tapes to do the repair and the tape isn't reusable.
The most trouble I had was making sure the display cable was reconnected properly, so definitely check the display is functional (especially the touchscreen functionality) before resealing the phone.
Thanks for publishing this guide, it was quite helpful.
val - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 40
过去 30 天: 160
总计 12,713
