跳转到主内容
加入维修社区 - 创建账户
Fixing Pop up Flash Receptacle
你所需要的
  1. Fixing Pop up Flash Receptacle, Battery: 步骤 1 中的图像 1,1
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
    询问修复机器人
    添加评论
  2. Fixing Pop up Flash Receptacle: 步骤 2 中的图像 1,1
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
    添加评论
  3. Fixing Pop up Flash Receptacle: 步骤 3 中的图像 1,1
    • Remove the battery from inside the battery housing and set the cover aside.
    询问修复机器人
    添加评论
  4. Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: 步骤 4 中的图像 1,2 Fixing Pop up Flash Receptacle, Fixing Pop up Flash Receptacle: 步骤 4 中的图像 2,2
    • The inside of the flash shoe has a removable cover which is just snapped in place.
    • Using the flathead screwdriver, pry up on the front end of the cover.
    • Warning: The cover is on tight and is tough to pry off.
    询问修复机器人
    添加评论
  5. Fixing Pop up Flash Receptacle: 步骤 5 中的图像 1,1
    • Loosen, but do not remove, the 4 screws on top of the flash shoe.
    询问修复机器人
    添加评论
  6. Fixing Pop up Flash Receptacle: 步骤 6 中的图像 1,1
    • Locate the black pludger sticking up out of the flash shoe.
    • The black pludger may not be visible, which is why the flash is broken. Just locate the hole to where it should be and move on to the next step.
    询问修复机器人
    添加评论
  7. Fixing Pop up Flash Receptacle: 步骤 7 中的图像 1,1
    • If you can remove the bracket from the camera to reset the hotshoe, this is preferable to using a paperclip to reset the sensors.
    • Push a paperclip in and out of the plunger hole, ensuring the plunger moves up and down freely.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
Mark
于04/20/11注册
197 声望
创作了5篇指南
团队
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 的会员
CPSU-REGAN-S11S8G9
4 名成员
创作了13篇指南
2指南评论
What about the other way, where the external flash IS installed (and the camera is successfully communicating TTL focal length data to it) yet the camera still doesn’t believe there is an external flash installed? Sometimes twisting the external flash a little causes the camera to change its mind and then it works, but then it usually forgets by the next exposure.
Think this mechanism could be causing that behavior too?
Andrew - 回复 分享
Take the hotshoe off, and make sure they move freely. Once they're moving freely, reverse disassembly and make sure it works. This will ensure it is properly "reset".
Nick - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 65
总计 5,279
