跳转到主内容
任天堂 Switch 屏幕更换
你所需要的
  1. 任天堂 Switch 屏幕更换, Joy Con 游戏手柄: 步骤 1 中的图像 1,3 任天堂 Switch 屏幕更换, Joy Con 游戏手柄: 步骤 1 中的图像 2,3 任天堂 Switch 屏幕更换, Joy Con 游戏手柄: 步骤 1 中的图像 3,3
    • 开始维修之前,请确保设备已完全关闭电源。
    • 按住 Joy Con 手柄背面的圆形小按钮。
    • 按住该按钮的同时,向上推动手柄。
    Kann ich diese Anleitung auch für die OLED anwenden? Habe im INet sonst leider nichts brauchbares gefunden.
    Ina Barz - 回复
    backup all your sd card data i had to format mine after this tutorial and lost all my game data
    JustForThisComment?ComeOn - 回复
    do not watch the video! i broke the metal shielding on my switch because they didn't mention a screw!!!
    Macro Man - 回复
  2. 任天堂 Switch 屏幕更换, 取下游戏手柄: 步骤 2 中的图像 1,3 任天堂 Switch 屏幕更换, 取下游戏手柄: 步骤 2 中的图像 2,3 任天堂 Switch 屏幕更换, 取下游戏手柄: 步骤 2 中的图像 3,3
    • 按住手柄背部的圆形按键,向上推动手柄直到将它与主机完全分开。
    • 按相同操作,卸下另一只手柄
  3. 任天堂 Switch 屏幕更换, 移除背盖螺丝: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    Magnetic Project Mat
    $19.95
    • 使用 Y00 螺丝刀拧下固定在后盖上的 4 颗 6.3 毫米螺丝。
    • 在整个维修过程中,请妥善保管每一颗螺丝 ,并保证在装回时每颗螺丝都能安装至原来的位置。
    Had to use a Y0 from my kit - the Y00 was too small to get a grip on the screw.
    cday - 回复
    I also had a much easier time with Y0 versus Y00. Y00 felt like it was starting to strip the first screw I tried to remove.
    Joe -
    My screws took a little coaxing before they were all ready to come out of the back plate, but I remedied this by turning the screwdriver as little as possible with each turn. Use almost no pressure, except for at the very beginning of each screw’s first turn.
    nin10doh - 回复
    I think my screws are stripped, any way to get them out?
    Banjomanperson - 回复
    I hear that using a rubber band can help? Not 100% sure on that though.
    Pifase -
    My top 2 screws are stripped, one into triangle, the other circle, rather than triangle spokes.
    AndrewDaPro - 回复
    This happened when I replaced the micro-sd card slot, which turned out to have replaced the broken one with another one that turns out to be broken. I need to fix the fact that when I reapplied the back cover, the vent was misaligned.
    AndrewDaPro -
    I had huge problems removing the bottom two screws. I continued with the next steps and lifted the plastic shell as much as possible while using the screwdriver and it became an ease.
    y0 works best. Press HARD at beginning then ease off to finish.
    J LWsMommy - 回复
    what to do if your screw is stripped??
    suru - 回复
    I haven't tried neither solutions that I am gonna propose here but
    1. Poor some Isopropyl Alcohol, one small drop will do, get a piece of cotton (not any clothing) and dip it in the Isopropyl Alcohol, apply and then try to get a grip with tweezers and turn it out
    OR (I do not reccomend it since it can cause huge damage if done wrong)
    2. Grab a small drill and drill through the screw. Keep in mind; the screw is very small.
    If you do one of these and it goes wrong, I am not responsible for that.
    DongComArts -
    I had to file down the point of the y00 bit. As it came, I was not able to get the back screws out. It would just slip in the screw.
    Dave - 回复
    Y1.5 is correct, perfect fit.
    Orpheus - 回复
    this is so difficult the screwdriver doesnt help AT ALL
    Issa - 回复
  4. 任天堂 Switch 屏幕更换, 移除顶部和底部螺丝: 步骤 4 中的图像 1,2 任天堂 Switch 屏幕更换, 移除顶部和底部螺丝: 步骤 4 中的图像 2,2
    • 使用 JIS000 螺丝刀,或者 iFixIt PH000 螺丝刀取下用于固定后面板的螺丝:
    • 一颗在主机顶部的散热器出口旁,长度为2.5毫米的螺丝
    • 两颗在主机底部的充电接口两侧,长度为2.5毫米的螺丝
    • 面板上的这些螺丝比较容易滑丝,为了防止滑丝发生,在拆卸过程中请用力向螺丝施加压力,同时缓慢拧动螺丝刀,如果螺丝无法拧出来,尝试换另一个JIS 000 或 PH 000 螺丝刀试一下。
    Hey guys, I tried removing the upper screw and it won't go out(neither will it go in) any tips how to fix this?
    Thanks
    Nemysis - 回复
    The screw boss might be stripped out. Has the device been taken apart before? If you can unscrew it a little bit to get the screw to peek out, maybe try and grab it with some pliers as a last-ditch effort.
    Craig Lloyd -
    I have the same problem. The JIS 000 tool works great on the joy con rails per step 5 but refuses to turn the bottom two 2.5 mm screws as in step 4. These bottom screws are noticeably smaller than the screws as in step 5. The JIS 000 does not get down into these screws. Hopefully they haven’t been stripped by the wrong tool. So is there a JIS tool that is smaller than 000? I’m stuck at this point…
    david brown - 回复
    We used the JIS 3.0mm screwdriver for both top and bottom screws and it worked
    Brooklyn Gardner - 回复
    Used PH00 to get these out with no problem.
    cday - 回复
    Fun fact: these screw into little plastic tabs that stick out of the rear panel. Apparently those tabs are fragile and easy to just break off…
    Benjamin Fritz - 回复
    If the screw is turning but not coming out, the plastic tab that it screws into is probably damaged or broken. You’ll need to try to pry the screw out with tweezers as you unscrew it. It is not the end of the world if you can’t screw these back in during reassembly.
    claudio ocano -
    My screws came out fine. But they are easily stripped with too much pressure on reassmbly
    Jaxon Lee - 回复
    this screws are way too fragile and way too small so be careful when taking them off dont use much force and unscrew also one of them fell somewhere and spent 30 mins searching for it
    Richard Aguirre - 回复
    PH000 will work if you don’t have JIS000. The large IFIXIT kit has both and I lost JIS000. Just be very careful as you can strip the heads when removing or inserting easier.
    Shawn Spivey - 回复
    One thing that worked pretty well for me with the screws not coming out is slightly prying on the back cover to put them under some tension
    Florian Kraupa - 回复
    I just came here to also confirm and say thanks to Florian for the tip. This saved me a lot of time and frustration.
    Jon Nielsen -
    Quick note, these screws are not magnetic. A magnetic screwdriver will hold onto any of the others safely, but you need to be careful not to drop these ones in particular.
    Jason Lane - 回复
    These would just keep rotating and not come out. What worked was, as Florian Kraupa suggested, i slid a plastic pick just between the 2 shells near the screws to prise it open slightly, then unscrewed and out they came. They're the smallest screws I've ever almost not seen before, so be careful with them.
    Susannah Carter - 回复
    Der Tausch von Akku (separate Anleitung) und Lüfter ging einfach vonstatten. Die Anleitung ist echt gut und leicht verständlich. Man sollte aber gewohnt sein, mit extrem kleinen Anschlüssen, Schrauben und Platinen zu arbeiten, da alles da drin recht klein ausgelegt ist und keine Toleranz für grobschlächtiges Arbeiten erlaubt! Meine Switch ist nun wieder wie neu :) - Danke iFixit!
    The swapping of battery (separate instruction) and fan was fairly manageable. The instructions are easy to understand. One should be used to handle with extremely finnicky connectors, screws and circuits as the components are really small and do not allow any tolerance for rough handling at all! My Switch is good as new again :) - Thank you iFixit!
    gerhardkoschany - 回复
    My original switch bought on launch day does not have any of these screws. I'm guessing they fell out since the plastic tabs they attach to are broken. FYI, in case anyone else does not have these screws...
    Michael Crook - 回复
  5. 任天堂 Switch 屏幕更换: 步骤 5 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 5 中的图像 2,2
    • 在设备两边,使用 JIS000 螺丝刀(或 iFixit PH000 螺丝刀)拧下2颗长度为3.8毫米,位于中央的中心螺丝(一面一颗)
    • 注意 如图所示,在主机的两面各有五颗螺丝,本步骤只需要拆除最中心的那一颗,其余四颗不需要拆卸。
    I tried my JIS 000 on Step 5 and was unable to get the screw to budge. It’s partner from the other side came right out with no trouble. Don’t really want to narf up the screw, so I bailed out. Anyone else have this issue?
    mrhoyt - 回复
    Could just be torqued down a bit more! I’d recommend making sure the driver bit seats nicely into the screw, apply some downward pressure, and slowly twist to try and back it out. Good luck!
    Craig Lloyd -
    Yeah I’m having this exact issue. Screw stripped and now I’m stuck. Wish I hadn’t even started.
    Ryan Quinn -
    I did finally get it out- one thing I noticed was some of the screws have blue Loctite on the threads. I guess they figure it’ll get tossed around. This underscores the importance of having the correct tools and making double darn sure you are using the correct size, etc.
    mrhoyt - 回复
    What worked for me here was a Phillips 000, not a JIS 000
    Federico Zivolo - 回复
    One of mine is totally stripped. Guess I can’t do anything now.
    Nick - 回复
    My kit only has two screwdriver heads! The package was open when I received it!
    Cynthia Hyland - 回复
    I had this issue as well. Screw was irreparably stripped. If you can get every other screw out, just keep applying pressure with a flat head screw driver right above the stripped screw and try to break the plastic piece holding onto the screw. It's a very minor invisible bit of damage that will allow you to continue the repair.
    Raymond Garrison - 回复
    after getting all the other screws off I just hinged the back part away and it snapped off neatly where the rusted screw is. not the best solution but it worked.
    Steve T -
    One of my screws was SUPER attached too, but after following a bit noticed the one other in the left that got out nicely, had the plastic tab broken already! So I went ahead and broke the other tab too. So the two side screws are now holding nothing. But I think it will work thanks to the other 4 or 5 screws. Too bad!
    carolaclavo -
    i managed to get out one screw by putting a bit of paper over it which gave the screwdriver something to grip. The other side just won't budge and gets worse the more i try.
    Steve T - 回复
    000 is too small, PH00 is right. Incorrect bit size will strip screws.
    Orpheus - 回复
  6. 任天堂 Switch 屏幕更换: 步骤 6 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 6 中的图像 2,2
    • 用手指翻起 Switch 主机背部用的支架
    • 注意: 如果卡槽里有 Micro SD 卡的话,在开始下一步之前需要先将它取下来。
    Don't put your SD card on your magnetic mat.
    Chris Cotter - 回复
  7. 任天堂 Switch 屏幕更换: 步骤 7 中的图像 1,1
    • 使用 JIS000 螺丝刀(或 iFixit PH000 螺丝刀)拧下位于主机支架下面,一颗 1.6 毫米的螺丝
    • 将支架盖上。
  8. 任天堂 Switch 屏幕更换: 步骤 8 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 8 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 8 中的图像 3,3
    • 从设备底部提起后盖并取下
    • 背部盖板连接到塑料外壳的另一半,防止你在关闭后面板时将其完全抬起。
    • 从设备底部向上提起后面板并将其卸下。
    How to remove micro SD port?
    Pull straight up, press back into place when closing back up.
    Christopher Hernandez - 回复
    This step is missing in this guide. Here are the steps from another guide:
    Step 9) 任天堂Switch的右侧Joy Con手柄滑轨的更换
    Step 10) 任天堂Switch的右侧Joy Con手柄滑轨的更换
    David - 回复
    When I lifted up the back cover, it kind of stuck near the headphone port (even with cartridge slot open). But it wasn't a screw or anything and I kind of carefully pulled and wiggled and the cover came off ok
    Doe - 回复
    +1, there is definitely an extra clip there on my day 1 switch
    repofmady -
    I wasn't so careful here and found out during reassembly that I accidentally broke off the clip with the screw hole on the top of the back cover (the clip fell off the device when I turned it over), so I can't put the top screw back in, but oh well at least the back cover is still affixed to the device otherwise
    Justin Johnson -
    Are the little foam pads on the bottom back of the panel needed? They were removed from a panel I have.
    Type1Guy - 回复
    If you're having trouble getting the back cover to fit during reassembly, check to make sure you don't have an SD card inserted in the slot. It will get in the way.
    If you're like me, you might have inserted the SD card to verify your SD reader was working again after doing step 9 reassembly. If so, remove it before proceeding.
    Alex - 回复
  9. 任天堂 Switch 屏幕更换, 移除MicroSD读卡器: 步骤 9 中的图像 1,1
    • 使用JIS 000螺丝刀或iFixit官方PH 000螺丝刀移除Micro SD卡槽上的1颗3.1 mm十字形螺丝。
  10. 任天堂 Switch 屏幕更换: 步骤 10 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 10 中的图像 2,2
    在这个步骤中使用的工具:
    • 用手或镊子,缓慢地垂直提起micro SD卡槽所在的子板,使其从主机上脱离,然后断开连接并移除它。
    • 在重新组装时,请对齐子板并轻轻地按压接口上的海绵垫,直到接头发出咔哒声为止。如果需要,你可以在安装前取下海绵垫。
    Yes. The reverse is not so simple- you can’t see what you’re doing when you attempt to reconnect and it only takes one small error to completely bend the contacts on the connector. Very delicate.
    if you very gently remove the foam pad sticker, you can at least see better how it lines up and can feel your way to a degree… then you can stick the pad back in. The pad seems pretty critical in keeping things in place once reassembled.
    holmzee - 回复
    Definitely agree about not sticking the foam pad back on until the new SD card slot is connected. Saved a lot of headache. Great walkthrough and easy repair!
    Jonathan Stachewicz -
    Tried several times to replace this SD reader module. As mentioned above, the issue is aligning the connectors together. It appears the foam tape is being used to hold the connection in place. (assuming you can make a viable connection) I am rather surprised at this design. In my experience, mylar ribbon cables like this usually slide into a small PC mounted socket. It appears Nintendo went the cheap route here. This design is prone to failure since it does not enable a positive connection - at least from what I can see.
    Bill Little - 回复
    Alors je suis en détresse total . Jai cassé les bouches en or sur le connecteur qui est soudé sur la carte mère.. comment changer cette toute petite pièces, oû la trouver . Cela fais 1 mois que je cherche partout. Sans remplacer la carte mère. Merci pour vos réponses
    Mike Snow - 回复
    I found it easier to connect it without the black foam pad so I could see and than add the foam pad over it. It was super easy and I an I 33 Mom doing this for my son. Was well worth the money for the kit saved us almost 100 bucks
    Katherine Harrison - 回复
    Had my son follow this guide to fix his own switch where the ad card reader didn't work. And he did. Great instructions!!!! Thanks a million!
    William Scott - 回复
    The only difficult part of following this guide is connecting the new sd card reader into the poorly designed motherboard connector. Its quite possible the sd card reader that came in the console wasnt broken at all.
    The repair kit works just as advertised and even comes with stickers.
    Matthias_ Links - 回复
    I’m still getting error 2002-2054 even after replacing memory card reader module. Thanks, Nintendo!
    Wes Stephenson - 回复
    My switch won’t read my microSD card after I reassembled it (error 2016-0641) please help!
    Nate Topical - 回复
    Tip: Keep the old SD reader piece loosely attached while you line up and gently press the new SD component into the connector on the motherboard. Once the new piece is snug, then carefully remove the old piece keeping the sticky foam in place.
    I am a middle-aged mom with absolutely no special tech skills and I easily followed the directions and successfully fixed the broken SD drive. ifixit is the best!
    Wende David - 回复
    Ah good! i have more confidence now in doing it once you said you're a middle age mom with no experience
    Mohammad Hosein Yavari -
    I missed this bit about reconnecting the SD card reader under the foam pad and didn’t realise until my son pointed out a data storage problem?. All fixed in about 5 minutes taking advice from the replacing the SD card reader fix, especially removing the foam pad from the connector to better see and feel what you’re doing. All sorted!
    Stuart Farquharson-Roberts - 回复
    Awesome guide! Very easy to do with the supplied kit
    cravenkeo khamone - 回复
    Tank you very much, and by tank I mean M1 Abrams, jokes apart easy and simple to follow
    Elia Veschi - 回复
    Thanks for the guide, I was struggling to find a solution, replaced more sd cards, before I stumbled upon this post. The Switch of my children works flawless again!
    Robert Morvai - 回复
    Doesn’t work! I have spent 4 hours and $26 on a tiny screwdriver and some stickers.. I just gave up and replaced the Switch instead.
    I even contacted a local shop to have them fix it and they told me it really isn’t possible. Thanks for taking my money Ifixit!
    J.R. Wood - 回复
    This helped me to reseat my SD card reader ribbon cable. I was getting the 2016-0641 error and no card work. A drop had dislodged the cable partially. And yes remove the foam pad gently to properly connect the cable. You can reuse the foam pad.
    Kris Morey - 回复
    For anyone who ends up bending the pins like I did while trying to reseat the microSD card reader…
    I suggest gently placing very thin tweezers (like the curved ones in the Pro Tool Kit) in the gap and very, very gently pressing them back into alignment. Took a little effort but I was able to realign them enough to sit it in place and have it later working after reassembling the console.
    Yakarot Sennin - 回复
    Anyone have a suggestion where I can purchase replacement foam for this sticker?
    Rob M - 回复
    When reassembling, note the alignment pins in the left and bottom notches before tightening the screw
    Jason Lane - 回复
    Super gemakkelijk te installeren met behulp van deze zeer duidelijke handleiding (met dank aan de vertalers!)
    Wel even goed opletten op de aansluiting op het moederbord is zeer fragiel.
    R de Bruijne - 回复
    It is key to remember most out of the box issues with the SD card reader, do not require a replacement part and can be solved with disconnecting then re-connecting the reader at the motherboard.
    Only when a simple re-seating at the connector doesn't work should you buy the replacement part.
    Jonathon Sinclair - 回复
    I bought the kit and followed the directions. I plucked the black rubber foam off with a pair of eyelash tweezers. Putting the tiny screws back in place also was made easier using the tweezers. As for placing the SD card in place I think I got a bit lucky. I lined it up and gently pressed until it simply went into place. I do believe being gentle is the key there. But it went in and I put it back together. The deconstructing and reconstructing is what took the longest for me at least. I turned it on to verify it worked and then unpowered the unit and inserted the card. The system recognized and update right away and did it and then recognized the card! Just what I need for 20 something dollars. Son is happy and back to gaming.
    Albert Baker - 回复
    Thank you for postingthis fix. The original sd card reader had come unplugged from the motherboard, so replacement reader will be a spare.
    Anybody found a way to ensure the sd reader stays in place?
    Craig Thwaites - 回复
    It was my first time repairing a Switch and the fan replacement wasn't too hard, but unfortunately I think there should be a better warning about the SD card connector because I damaged it while trying to put it back in. I couldn't hear any click and it didn't seem to stay put and I think I ended up applying to much force and damaging the pins.
    Serge Huber - 回复
    What are the foam black squares called and where can I get a replacement for one?
    Marcus - 回复
    It’s called Foam tape
    Alberto -
    What is the error code 404 for
    Alberto - 回复
    Managed to push the connector back in with foam on, used back of plastic tool to push secure and once completed was able to use the SD port again. Brilliant little guide.
    Dominic Jones - 回复
    so how would you theroedictly put the old slot back on.
    and how does if even work
    Shadow Dragon - 回复
    Horrible guide, incomplete. Needs to show how to reattach the new reader but doesn't show anything. This makes it incredibly easy to bend pins that become incredibly difficult to fix. Ended up bending pins on the connector beyond repair as I didn't know what to look for or how to reattach it. Wouldn't recommend
    Blake Thorne - 回复
    Tried to do this, everything went smoothly I thought, but when I turn on system w SD card in the new slot, immediately freezes up the system completely until I hard shut down. Did I do something wrong?
    Nate Akers - 回复
    "Draw the rest of the !@#$ing owl"
    Droideka30 - 回复
    I have an issue that when I insert the SD card with the case off (to test the connection is correct), the switch reads it no problem. When I put the case back on, it no longer reads it. Anyone else experienced this?
    Adam Seager - 回复
    This bullshit replacement part broke after two weeks of use, and now the connector on the board is damaged. My Switch is probably &&^&@@.
    Thanks, iFixit!
    Thomas Buster - 回复
  11. 任天堂 Switch 屏幕更换, 移除屏蔽板: 步骤 11 中的图像 1,1
    • 使用 JIS000 螺丝刀或 iFixit 菲利普000螺丝刀,移除屏蔽板上的6颗3mm的十字形螺丝
    Some models have a small board in the lower left beneath the kickstand which accepts SD cards. This will have to be carefully removed with its connections popped out, then replaced after.
    Draque Thompson - 回复
    Yeah, that “small board” is the microSD Card reader chip, which was covered literally one step ago. All models have a microSD Card reader, that’s how game data is stored…
    nin10doh -
    My switch had loctite (or similar) on the bottom right screw (farthest right), ended up striping it and having to use a Dremel to cut a slot in the screw to get it out. I've heard that heat (solder gun) can be used to loosen loctite, hindsight. Only screw I found with loctite.
    Rachael Webster - 回复
  12. 任天堂 Switch 屏幕更换: 步骤 12 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 12 中的图像 2,2
    在这个步骤中使用的工具:
    • 用手指或镊子剥下设备顶部边缘靠近风扇排气口的泡沫片。
    • 如果泡沫不容易剥落,请不要强行撕开,否则可能会撕裂。 小心地在不同的地方剥离,最终完全剥离泡沫。
    My Switch (bought about two weeks after launch) seems to be missing this foam piece… Was it added later, similar to the foam piece in the left joy-con (to improve connectivity)?
    firetech - 回复
    It’s possible it was added to newer units! Nintendo slightly updated the internals of the Switch not too long ago.
    Craig Lloyd -
    My launch Switch also does not have this piece of foam, so it was most likely added later.
    Christoph -
    Also did not see this in my launch switch.
    matthew.raehl - 回复
    Me three, no foam.
    carolaclavo - 回复
  13. 任天堂 Switch 屏幕更换: 步骤 13 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 13 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 13 中的图像 3,3
    • 沿设备边缘在屏蔽板下方插入撬棒。
    • 向上撬起屏蔽板。
    • 您可能会感到有点阻力。 这是正常现象,因为屏蔽板和散热器之间有导热膏——稍微有点黏性。
    • 在铜质热管和屏蔽罩之间涂有一层粉红色导热硅脂,这有助于防止 Switch 过热。
    • 如果你足够小心的话,你可以重复使用这些粉红色导热硅脂。只要硅脂保持干净,并确保在重新组装时它与散热器和屏蔽罩紧密接触。
    • 如果您需要更换它,请参考我们的散热硅脂更换指南来移除旧的散热硅脂并为其在重新组装时更换合适的硅脂,例如K5 Pro
    How do you know if the thermal paste needs to be replaced?
    Youji Hong - 回复
    Once you remove a heatsink you must always replace thermal paste even if you had just applied it ( or add a little more) . The reason is that once heat sink is fitted, paste splits around because of pressure and only needed amount will remain. If you remove the heatsink then some paste will move so when installed again there will be spots without paste. Hope this is clear enough. In any case cost of paste is very small compared to work time and value of your equipment…..
    MacTek -
    When your switch starts to lag and drop FPS, if you play breath of the wild and it starts to slow down in heavy areas like the forest where you get the master sword, can i use artic mx 4 insted of the pink compound?
    Diego Soto - 回复
    I’d like to know as well if a cpu thermal compound like arctic mx-4 can be used to replace the pink compound
    Adam Stillman - 回复
    No you shouldn't . It will spill around because it is not viscous enough and then there will be no heat transfer. As suggested by author K5 PRO is the most appropriate compound for such cases.
    MacTek -
    Arctic is generally only supposed to be used on bigger heat sinks like a personal computer. Its not nearly as thick or gummy compared to K5 PRO, and you should always use something that’s thicker for smaller project like a Switch/phone/tablet.
    Shawn Christensen -
    Why was this not included in the tools/equipment list? Getting to this step and now I will have to reverse and wait for yet another order to arrive. ? Very frustrated
    Amanda Nally - 回复
    Hi Amanda,
    Thanks for bringing this up. Sorry! We inadvertently left that part out during the guide refresh. I’ll add the necessary info into the step.
    Arthur Shi -
    I agree with Amanda, hopefully I don't lose any parts before I can get the paste. This seems like it should almost be included in this kit from what I've read about this repair. Mine certainly needs to be replaced. I feel like at the very least, this should be at the top of the guide and part order page in bold, red, all cap lettering.
    Side note this is the only "issue" I've had of the 4 purchases I've made with ifixit. I recommend you guys every chance I get. I really enjoy doing these repairs with my son.
    Zach Bryson -
    To apply new thermal paste, the directions state to use the application method recommended for your specific processor type—vertical line, horizontal line, middle dot, or surface spread.
    Which method should be used for the Nintendo Switch processor?
    Philip W - 回复
    As stated in the comment above, is there a particular method to apply thermal paste to the Switch’s processor? Or as long as you distribute it evenly is enough?
    lievjorg - 回复
    Is another thermal compound as MX4 or 6 okay as well?
    Marceau - 回复
    does ifixit not have an appropriate thermal paste for this step?
    there is only arctic silver 5 in the kit and i would guess that that should not be used in this case.
    if true, the kit is incomplete
    Lucas Tigy - 回复
    This step is also completely glossed over in the YouTube walkthrough, which doesn’t even hint at the existence of the pink paste.
    Phokal - 回复
    Since I couldn't find decently priced K5 I used a 0.5mm thick thermal pad and that seems to have done the trick quite well.
    Dupont Nicolas - 回复
    The Amazon link goes to a kit with 6 tubes of K5 Pro. Surely I don’t need 6 tubes… is this kit sufficient? https://a.co/d/5aU8kB7
    JAVH - 回复
    When replacing the thermal paste, is it possible just to clean the old thermal off the back plate and top of the copper heatsink and just re-apply those areas only, without removing that copper heatsink?
    Linn Mckay - 回复
  14. 任天堂 Switch 屏幕更换, 断开电池: 步骤 14 中的图像 1,2 任天堂 Switch 屏幕更换, 断开电池: 步骤 14 中的图像 2,2
    • 在将撬棒的底端伸到白色插头的地下然后向上移动将其从主板上撬下。
    be careful not to pry it off the board entirely
    Nathan McKenna - 回复
    This was an old switch and the entire thing with the black plastic came off.. Most of the pins aren't there anymore, too.. is there a solution to that? Does soldering work?
    Dawn Martin -
    it's probably possible, but unless you have experience with microsoldering, you'd probably be better off taking it to a local repair shop
    just some mango -
    This step just ruined my device… wish there had been a warning of caution here.
    Phone guy - 回复
    You can use a spudger to hold down the black plastic side of this connector that is supposed to stay attached to the motherboard while using the pointy spudger as shown in order to reduce any chance of pulling the socket off the motherboard.
    Brian Edgin - 回复
  15. 任天堂 Switch 屏幕更换, 移除散热槽: 步骤 15 中的图像 1,1
    • 使用 JIS 000 或 iFixit PH 000 螺丝起子卸下将散热器固定到主板的三颗3毫米螺丝。
    • 小心地将粘在散热器和风扇上的两个泡沫片从风扇上剥离。
    • 只需将泡沫剥离到足以清洁风扇的程度。
    • 泡沫片十分脆弱,很容易撕裂。 使用下面的方法剥离泡沫:
    • 将撬棒的尖端插入泡沫片下方没有粘住任何东西的部分,
    • 用手指按压泡沫片顶部以将其固定到位。
    • 将撬棒尖端一直滚动到泡沫片下方的另一端让泡沫片分离。
    spudger technique is perfect.
    Jaxon Lee - 回复
    For anyone who doesn’t have a pen-style spudger, the tip of your JIS 000 screwdriver can be a great alternative tool. The same steps above can be used, just be extra careful not to tear that foam. Roll the tip of the screwdriver the same way you would roll the spudger tip.
    nin10doh - 回复
    Maybe it’s because I’m working on a day one switch and the adhesive is just old and stubborn, but this didn’t work well for me. Am I just completely out of luck, or can I order a replacement for the foam?
    Trae Block - 回复
    I had the same problem and I found a foam manufacturer: https://www.foam-material.com/sample-cus...
    I'm pretty sure the type is "Granular Activated Carbon Foam" and the thickness is 0.5 mm but I have no idea what the porosity is.
    Garret Jaworski -
    Yeah ripped the foam. Neither the screwdriver nor spudger technique worked. Day one switch, so 6 years old at this point.
    Ndragonawa - 回复
    Does the foam need replacing if torn? What does it actually do.
    Scott Norman - 回复
    I wanted to know as well, what does it do? Can I replace it with thermal pads?
    Lord Aranorde -
    Can I replace the foam with a 0.5mm thermal pad? Will it be a better solution?
    Lord Aranorde - 回复
    The adhesive remover really helped here being a day one switch
    Jeremy Ortner - 回复
    Day One Switch, used the spudger technique and 1 teardrop of adhesive remover, no foam ripped here! Technique is mint.
    Cassitar - 回复
    how do you re-glue the foam when putting this back together?
    Elias Cooper - 回复
  16. 任天堂 Switch 屏幕更换: 步骤 17 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 17 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 17 中的图像 3,3
    • 用撬棒或手指将散热器提起并从主板上卸下,以将其卸下。
    • 你可能会感到有些抵触。这是正常现象,因为散热器会通过散热胶与CPU轻微粘合。
    • 使用高浓度(90%或更高)的酒精和超细纤维布清除散热器和CPU上的旧散热膏。重新组装前,请在CPU上涂抹新的散热膏
    • 将散热膏均匀地涂在之前涂过的位置。这包括散热管和铝合金屏蔽罩之间,Switch用来额外散热的那个地方。
    What's on the heatsink?
    Unknown1224 - 回复
    Directions for this step say you can use Artic Silver ArctiClean but when adding to iFixit cart it says “This won’t work with your device (Nintendo Switch).
    Dan S. - 回复
    where do i get more of that black fabric like tape that is on the heat sink?
    Regal Pikachu - 回复
    They may sell it in the ifixit store.
    Joshua Graham -
    (1) Exactly how much thermal paste should be applied to the CPU?
    (2) Which application method should be used? The linked instructions list four methods (vertical line, horizontal line, middle dot, or surface spread) but it’s not clear to me which one is appropriate for the Switch. Thanks!
    Travis - 回复
    UPDATE: So, for anyone who also wanted to know the answers to these questions:
    1. I ended up eyeballing the amount. Imagine an amount the size of a pea, then split that amount in half. That’s how much I used, and it worked fine.
    2. The paste (I used K5-Pro as recommended) is quite thick and sticky and difficult to get to behave the way you want, so I ended up just doing the “middle dot” method and spreading it a bit with a popsicle stick before smushing it the rest of the way down with the heat sink. Seems to have done the trick.
    Good luck!
    Travis -
    you can also spread it with the spudger or any non-metalic tool if you are not sure how much you put
    just clean it afterwards
    Richard Aguirre -
    K5 (or thermal pads) is ONLY needed between the copper pipe and metal shield plate. It is a pad replacement compound and is not meant for high heat applications like CPUs as it boils and creates air gaps. Air=bad for heat transfer.
    Regular thermal compound/paste should be used on the CPU. You’ll have a sticky mess to clean but if you want proper cooling it needs to be done. The instructions clearly state that regular compound is used on the CPU.
    Cerus98 -
    i used artic silver 5 and worked just fine
    The steps doesnt specify but do you have to remove the heat shield from the cpu as well?
    Jeremy Ortner - 回复
    I'll be doing this with Thermal Grizzly kryonaut this weekend, wish me luck
    Corradon - 回复
    good luck with the repairs!
    pkjnyoung -
  17. 任天堂 Switch 屏幕更换, 移除耳机接口: 步骤 18 中的图像 1,2 任天堂 Switch 屏幕更换, 移除耳机接口: 步骤 18 中的图像 2,2
    • 使用打开工具或指甲将数字转换器电缆的ZIF连接器上的小夹扣锁定翻盖向上翻转。
    This step broke my switch i can't use my card reader anymore! i tried numerous time the reverse it seems my headphone jack works but my touchscreen and gamecard reader is broken. Even worse one of the screws to attach this plate was mangled so i cant even replace it anymore because the screw wont come out anymore. I reallly hate that i followed this guide others suggested to just keep the gamecard touchscreen ribbon attached and just fold it like a book. I wished i did that. I not gonna bother to even buy an gamecard replacement anymore. Its time to buy an switch oled and be done with this!
    Kar Wai Chan - 回复
    The advice to "fold it like a book" will not work, as the cable will need to come out of the switch in order to replace the screen. It can not be kept in the slot.
    Loris Hofer -
    To anyone reading this step: This is not an isolated incident. The loss of functionality of the game reader board, which includes the use of reading cartridges, the touchscreen, and the headphone jack, is an possibility that can happen if you disconnect the board. Unless you are replacing the board itself, do not do this step. As of 1/15/2023, there is no know reason why this happens or no known solution other than buying a new game reader board.
    Henry Terrance -
    Update: If your Switch has lost the ability to read games and or the headphone jack in addition to touchscreen functionality, please consider reading this thread and its solution: Nintendo Switch Cartridge Reader Not Working After Fan Replacement
    Henry Terrance -
    it is really hard to see what you need to flip up. look at it from different angles. it's the thinnest little strip of black plastic.
    Patrick Laffan - 回复
    If you're scared of breaking this piece, you can skip step 18 and 19, and just flip the reader over to the left (after step 20-22). Worked for me, be careful though it might bounce back.
    Cato_nm - 回复
    Please help I replace the game card read and head phone. Now my switch wont even turn on.
    Chase Blackstone - 回复
  18. 任天堂 Switch 屏幕更换: 步骤 19 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 19 中的图像 2,2
    在这个步骤中使用的工具:
    • 镊子将数字转换器排线从游戏读卡器电路板上的接口中拔出。
    • 在重新组装时,插入排线之前,请确保 ZIF 接口的锁定卡扣已被翻起
    • 将排线与电路板平行,轻轻地将其滑入接口中。
    • 不要强行将排线插入接口。如果无法插入,请确保锁片已向上翻起,重新放置排线,然后重试。
    • 如果您的触摸屏在维修后无法工作,但您的读卡器可以工作,请确保此排线已正确插入。如果您的游戏卡读卡器也无法正常工作,请在下一步中检查读卡器。
    The reverse of this is a little tricky - it may be helpful to post some more detail about getting the ribbon all the way back in and ensuring the clasp goes down to troubleshoot some of the touchscreen comments below.
    Nick Wagner - 回复
    This seems to be purely for the touchscreen to work, if you remove the headphone/card reader the switch will still function fine, however without somewhere for this cable to reattach your touchscreen will be disabled
    Ian Wilson - 回复
    the reverse of this is tricky. i'd suggest a better tool kit with this that includes real tweezers so i don't have to use my wife's
    Patrick Laffan - 回复
    Did you get it to work finally?!
    Chris Cotter - 回复
    Hi Chris! From the thread, it looks like it's not this connector that's the problem, but the press connector in the step below. If your card reader won't read cards, check to make sure this connector is fully aligned and seated.
    Arthur Shi -
    This connection was a problem for me. I tried the connection many times before it worked. What finally worked was lining up the gold rectangle on the back of the smaller part to overlap/cover the port very carefully. This required me to compress the ribbon a bit. Not much force required to finish the connection.
    Tyler Rhodes - 回复
    I found it much easier to reinsert the ribbon while the reader board was fully disconnected. This way I was able to simply hold the reader board with my fingers and slide it over the end of the ribbon while the ribbon was just sticking up in the air. The ribbon is quite stiff and slipped in VERY easily in such a way that I felt confident that it was fully seated. Then while holding it in one hand, I flipped the locking flap down with a spudger in the other. You might also be able to seat the board and the ribbon will likely stay inserted under its own tension, then flip the locking flap down.
    Brian Edgin - 回复
  19. 任天堂 Switch 屏幕更换: 步骤 20 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 20 中的图像 2,2
    • 用撬棒的尖端笔直向上撬起耳机插孔和读卡器,以将其与主板断开连接。
    • 重新连接像这样的压接式接口,请小心地对齐并向下按一侧,直至其卡入到位,然后在另一侧重复。不要直接在中间按压。如果连接器未对准,引脚可能会弯曲并造成永久性损坏。
    • 如果重新组装后触摸屏无法正常工作/或未检测到游戏卡,可能是此接口没有重连到位。请小心地断开连接,然后重试。
    Note that if the card reader mentions it won't read cards, this cable has not been reconnected correctly. Watch the connectors are not bent when reattaching
    Shaniqua Bowdre - 回复
    You need to push the connector upwards. Look at the image and you will see a very slight bend. This bent allows the connector to align with its dock. Very very careful when pressing down IT HAS TO BE ALIGNED.
    Juan Visani - 回复
    This step had me most stressed during re-assembly. I saw in a video elsewhere where the person reattached the press connector BEFORE screwing it back in which gave them more room to work with. They also pointed out that there's an outline on the top that should line up with where it reconnects. This helped me re-connect with more confidence.
    Level 100 Psyduck - 回复
    I also reconnected this connector before screwing the reader down. You will not have to contend with the pressure from bending the stiff wide cable leading from the connector.
    claudio ocano -
    커넥터 위의 사각형을 소켓 위치에 맞추세요.
    faddk79 - 回复
  20. 任天堂 Switch 屏幕更换: 步骤 21 中的图像 1,1
    • 使用JIS 000或iFixit官方PH 000螺丝刀,将固定耳机孔和读卡器电路板到机身的三颗3.1毫米螺丝卸下。
  21. 任天堂 Switch 屏幕更换: 步骤 22 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 22 中的图像 2,2
    • 用镊子或手指卸下耳机插孔支架。
  22. 任天堂 Switch 屏幕更换: 步骤 23 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 23 中的图像 2,2
    • 用镊子或手指卸下耳机插孔和游戏卡读取器板。
  23. 任天堂 Switch 屏幕更换, 屏幕: 步骤 24 中的图像 1,2 任天堂 Switch 屏幕更换, 屏幕: 步骤 24 中的图像 2,2
    • 使用打开工具,撬棒或指甲将LCD带状电缆ZIF 接口上的小铰链锁定翻盖向上翻转。
    How to replace locking flap incase it flys off
    Jonathan D'Costa - 回复
  24. 任天堂 Switch 屏幕更换: 步骤 25 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 25 中的图像 2,2
    在这个步骤中使用的工具:
    • 镊子将带状电缆直接从主板上的接口中拉出。
    I’ve torn a few ribbon cables in my time. Use your tweezers to nudge the tabs on either side of the ribbon cable and “walk” the ribbon cable out of the ZIF connector - slowly!! This should help prevent any tears in the ribbon cable when using tweezers.
    nin10doh - 回复
  25. 任天堂 Switch 屏幕更换: 步骤 26 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 26 中的图像 2,2
    • 使用打开工具,撬棒或指甲将较小的LCD带状电缆ZIF接口上的小铰链锁定翻盖向上翻转。
  26. 任天堂 Switch 屏幕更换: 步骤 27 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 27 中的图像 2,2
    • 用镊子将带状电缆直接从主板上的接口中拉出。
  27. 任天堂 Switch 屏幕更换: 步骤 28 中的图像 1,1
    • 加热 iOpener 并将其涂在屏幕的底部边缘约两分钟,以帮助软化粘合剂。
    • 也可以使用吹风机,热风枪或热板,但请注意不要使设备过热-显示屏和内部电池都容易受到热损坏。
    I used a hair dryer because I don’t own a microwave and didn’t like the idea of boiling the iOpener - which apparently doesn’t work that well anyway. For reference, the hair dryer I used was a CONAIR 1875 Styler. I also used an infrared thermometer, which you’ll absolutely need if you’re not going to use the iOpener. You need the infrared thermometer because you must know when to stop heating the digitizer. There are delicate components nestled in the top of the Switch’s faceplate - right where you’ll be putting the heat. To begin:
    1. Prepare your work area by clearing the surrounding surfaces of anything plastic, metal, or electronic - surrounding areas are sure to reach temps of up to 110 °F (43 °C).
    2. Get something non-conductive like a small cardboard box to rest the disassembled Switch on top of. This will help to target the heat on the specified area, depending on which step you’re on.
    nin10doh - 回复
    3. Grab a piece of cardboard and cut it to the shape of the Switch screen, or around the same size. You will need this cardboard to protect the LCD and delicate internals.
    4. Set your infrared thermometer to the side or somewhere close to the spot where you’ll be heating the digitizer.
    5. Grab your hairdryer and set that to the side as well.
    6. Position the Switch on the cardboard box so that you are ready to begin heating the first side of the digitizer as specified in Step 28. I found that it was easier to have the heated side facing me, so that I can hold the hairdryer more comfortably.
    7. Begin heating the bottom of the digitizer, starting on the lowest setting of your hairdryer. You’ll want to hold the hairdryer just close enough that you have about three or so inches between the heat and the Switch itself. Heating the digitizer will take some time, so do not expect the temperature to rise rapidly. A rapid rise in temperature can damage sensitive internal components, even with the cardboard piece in place.
    nin10doh - 回复
    8. After 1 min 30 sec, check the digitizer temperature and make sure that the surface temperature (the opaque black border, not the actual screen) registers at 130 °F (54 °C) or higher. Continue heating on Low until a temperature of 130 °F (54 °C) or higher is reached.
    9. When a temperature of 130 °F (54 °C) or higher has been reached, raise the hairdryer another two to three inches from the digitizer. Switch your hairdryer heat setting to High ( or Med, for three-temp hairdryers) and continue heating until a temperature of 161 °F (71 °C) has been reached. Check the temperature every 2 secs to ensure even, consistent heating. Once a temperature of 161 °F (71 °C) has been reached, do not heat the digitizer any further. Doing so could damage the LCD, internal antennas, or faceplate.
    10. Repeat steps 6 thru 9 alongside the guide (Steps 28 thru 38) to complete the digitizer adhesive softening process.
    Good luck! If this causes anyone any problems, reply here and I’ll try to respond as quickly as possible.
    nin10doh - 回复
  28. 任天堂 Switch 屏幕更换: 步骤 29 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 29 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 29 中的图像 3,3
    • 在屏幕的左下角使用吸盘。
    • 用稳定的力将其向上拉起以形成间隙。
    • 这可能取决于设备的使用年限。如果遇到麻烦,请多加些热量再试一次。
    • 将三角撬片的尖端插入间隙中,确保仅插入约5毫米的三角撬片。
    Used a heat gun at 3/4 power for TWO 2-min bursts. The remainder of the sides each took a single 2-min burst.
    Jaxon Lee - 回复
  29. 任天堂 Switch 屏幕更换: 步骤 30 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 30 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 30 中的图像 3,3
    • 沿着屏幕的底部边缘滑动开口撬片以切开胶粘剂。
    • 并保留插入的撬片以防止胶粘剂再次粘在框架上。
  30. 任天堂 Switch 屏幕更换: 步骤 31 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 31 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 31 中的图像 3,3
    • 将第二个三角撬片插入第一个撬片左侧的间隙中。
    • 然后将三角撬片朝设备左侧滑动。
    • 将三角撬片插入。
  31. 任天堂 Switch 屏幕更换: 步骤 32 中的图像 1,1
    • 加热屏幕的左边缘约两分钟,以帮助软化粘合剂。
  32. 任天堂 Switch 屏幕更换: 步骤 33 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 33 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 33 中的图像 3,3
    • 继续围绕左下角滑动三角撬片以切开粘合剂。
  33. 任天堂 Switch 屏幕更换: 步骤 34 中的图像 1,2 任天堂 Switch 屏幕更换: 步骤 34 中的图像 2,2
    • 沿着屏幕的左边缘继续滑动开口片以切片以粘合。
    make sure to follow exactly which side it says to do... i just sliced straight through the digitizer cable doing this ^^" whoops
    qu in n - 回复
  34. 任天堂 Switch 屏幕更换: 步骤 35 中的图像 1,1
    • 加热屏幕顶部约两分钟,以帮助软化粘合剂。
  35. 任天堂 Switch 屏幕更换: 步骤 36 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 36 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 36 中的图像 3,3
    • 继续在屏幕的左上角滑动打开挡片,以切割胶粘剂。
  36. 任天堂 Switch 屏幕更换: 步骤 37 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 37 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 37 中的图像 3,3
    • 沿着屏幕的顶部边缘继续滑动三角撬片以切开粘合剂。
  37. 任天堂 Switch 屏幕更换: 步骤 38 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 38 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 38 中的图像 3,3
    • 将屏幕的右边缘加热约两分钟以帮助软化粘合剂,
    • 将撬棒的扁平端沿屏幕的左边缘放入缝隙中,
    • 小心缓慢地提起屏幕的左边缘,将其像书一样打开。
    My digitizer separated from the lcd screen during this step. Wasn’t a problem. Just something to be aware of
    Jaxon Lee - 回复
  38. 任天堂 Switch 屏幕更换: 步骤 39 中的图像 1,3 任天堂 Switch 屏幕更换: 步骤 39 中的图像 2,3 任天堂 Switch 屏幕更换: 步骤 39 中的图像 3,3
    • 将屏幕的右边缘垂直提起设备,使带状电缆穿过框架。
    • 并注意不要将任何带状电缆卡在框架上。
    • 如果屏幕胶条仍然保持较高粘性,您可以重复使用它。否则,请用Tesa胶带等双面胶带更换旧的胶条。
    What kind of glue is required to re-assembly the screen?
    Deedend 77 - 回复
    only thing missing. I am scraping the old adhesive off and trying to re-use
    Jaxon Lee -
    UPDATE: So, I was able to peel off the re-apply the old adhesive. It seems pretty secure, but we’ll see. Otherwise, this step needs an additional detail about what type of adhesive would be ideal to finish this.
    Jaxon Lee - 回复
    Hi Jaxon!
    Thanks for the suggestion! I added an extra bullet for the adhesive.
    Arthur Shi -
    thank you for the help
    Cifiboy - 回复
    How many mm wide Tesa tape should I purchase?
    Keishin Tamaki - 回复
    Does anyone know where to find a replacement for the clear adhesive? I successfully completed the repair but the digitizer keeps separating from the screen.
    Digital Queen - 回复
结论
将新的替换零件与原始零件进行比较。在安装之前,你可能需要转移剩余的组件或从新零件上除去粘性衬纸。
要重新组装设备,请按照逆序进行操作。将电子废物带到[[E-Waste | R2或e-Stewards]认证的回收商| new_window = true]]。
如果在启动设备后新屏幕无法正常工作,请关闭它,然后断开并重新连接电池接口。
维修没有按计划进行吗?尝试一些基本故障排除后的故障排除,或向我们的 Nintendo Switch 社区寻求帮助。
50等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Craig Lloyd
于02/10/16注册
38,614 声望
创作了82篇指南
4条评论
What size tesa tape best fits the original (not OLED) switch? I have a slightly loose screen and don't want to disassemble to measure without having the right size on hand.
pvantilb05 - 回复
I followed the steps, however the screen only works/lights up if I push on the screen. Any idea what I did wrong?
Hannah Henderson - 回复
The Screen and Screen assembly are out of stock...can I buy the LCD, Digitizer etc and assemble them myself?
James Bowkett - 回复
Step 27 - I pulled the ribbon connector off the board. Can I solder it back on?
mmhekh - 回复
添加评论
浏览统计数据:
过去 24 小时: 43
过去 7 天: 302
过去 30 天: 1,271
总计 86,435
