跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
Nokia E90 is a 3G smartphone made by Nokia and the latest model of the Communicator series.
Can I get a board connector
while removing the strip from the board .. i broke one of the connector which connects the strip to the board ... how can i fix it .... or i have to place a new connector ..
and where can i get a connector too.. :-(
my model is nokia e90
there are two similar connectors at the side of the logic board .. near the camera ... i think it comes from the display ..
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
There are a few connectors on the logic board? Which one did you break?
完成的
完成的
i have uploaded a image of it ..
完成的
Where did you place the images :)?
完成的
now i have placed it ... can u see it :-)
完成的
显示更多的2条评论
添加一条评论
1个答案
已选择的解决方案
chaman, that is a Coax connector. Listed as X4500 in the schematic. The Nokia part number is 5429117 N-SERIES CONN COAX 30POL F VERTICAL 50V 0.3A P0.4 It is also used in the N93i. Of course, it is solder on the logic board and will require some pretty good soldering skills. The only places I could find are in Europe, one being in Finland. You may want to do a Google search. Hope this helps, good luck.
这个答案有帮助吗?
得分 1
2条评论:
ya but its very difficult to find it in india ,, i am not going to do the soldering thing .. it would be done by the my mobile repairer .. and i dont know how to get the connector ...
完成的
chamann, there is one here and another one here and here is one from Finland. All you have to do is go online and purchase one and I am not sure how I can help you with that. I can't seem to find one in India, but you may have better luck.
完成的
添加一条评论
添加你的答案
chaman 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 8
总计 1,600
