跳转到主内容
加入维修社区 - 创建账户
经过彻底重新设计的 Optima 与其姊妹车型 Hyundai i40 共享平台,在韩国和中国市场被称为 Kia K5,并于 2010 年纽约国际车展上首次亮相。
What sensor causes this error?
I have redacted the VIN, nothing more
So this issue is not new - the last time it occurred on this car, the mirror was known bad and apparently at the time, intermittent until it hard failed. I replaced the mirror with an aftermarket part and it was good for ~2-3 months after calibration, but the issue has come back. I scanned it, cleared it and outside of the known TPMS codes which persist because at the time I forgot about it, the ADAS code is persistent.
The only other thing I can think here is with the C207354 code coming back is the bumper sensor is at fault. Looking for a second opinion.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
@nick I concur and this does seem to come from the bumper sensor. Check Kia's TSB BLIND SPOT DETECTION (BSD) SYSTEMon that one. Looks like it's time for some reflashing ;-)
这个答案有帮助吗?
得分 1
4条评论:
I have read these are prone to liquid in the connector. Might be worth a look before having a reflash done. I did see the TSB but was looking around for other ideas.
由完成的 分享
@nick according to the TSB seems like a common error with this model
由完成的 分享
@oldturkey03 Figures. I at least have the TSB and can push them to fix it for free, and receipts with the code from the scanner, with and without the TPMS codes to show it is persistent.
由完成的 分享
So the car was beyond calibration and not subject to the TSB and apparently it came back, so the bumper sensor is dead on that side. Welp, at this point at least I know the rear bumper is coming off to get to it :/. The expensive DIY part is the ADAS scanner >_<. Even OTOFIX (cheaper Autel) doesn't have anything that can do ADAS.
The irony is to get it professionally calibrated after swapping the part out is the cost to have a shop do the reset after replacing the part (and checking the frame for damage just in case) to be sure it doesn't come back is it's as expensive as buying the scanner, pairing it to the car and then letting it calibrate in traffic xD.
由完成的 分享
添加一条评论
添加你的答案
Nick 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 43
总计 259
