跳转到主内容
加入维修社区 - 创建账户
索尼 PlayStation 5 DualSense 手柄(第一代)的维修指南、拆解和故障排除信息,它是 DualShock 系列的继任者。可通过型号 CFI-ZCT1W 和主板型号 BDM-010 进行识别。
PS5 DualSense Controller Triangle Button Stopped Working
Hi,
My son dropped my controller a few times and all of a sudden the triangle is not working very well. Sometimes it works, sometimes it doesn't. I tried cleaning it up from the outside and I'm a bit sceptical about opening it as I might just make it stop working completely. Does anyone have experienced something like that? R2 trigger is also in the same condition (sometimes it works, sometimes it doesn't).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi there!
Can you still press them in? How does the button feel? Still "Clickable"?
If not, you might want to clean everything inside (with isopropyl alcohol) and replace the rubber.
Guide: Sony DualSense Controller Buttons Replacement - iFixit Repair Guide (till step 33).
If that doesn't work, then you need to replace the button circuit membrane... There is no guide for it, yet. But you can follow the same guide to get there.
Regarding the R2, try cleaning first! If that doesn't work, then you might want to replace the trigger assembly..
Guide: Sony DualSense Controller Trigger Assembly Replacement - iFixit Repair Guide
Please let us know what worked or not!
DualSense Trigger Assembly图片
指南
难度:
中等
1 - 2 hours
DualSense Buttons图片
指南
难度:
中等
1 - 2 hours
这个答案有帮助吗?
得分 2
2条评论:
Hello! Yes, I can still press the button and sometimes it works but for some reason it just stops working now and then.
I will try with your first option and write here if that actually worked or not. Thanks for the tip. Hopefully I won't break it :')
完成的
Alright, yes then cleaning would be the first thing to do! Hopefully the controller will remain intact. Good luck with the repair :)!
完成的
添加一条评论
添加你的答案
Ricardo MVG 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 97
总计 981
