跳转到主内容
加入维修社区 - 创建账户
Sony DualSense Controller Buttons Replacement
你所需要的
    1. Sony DualSense Controller Buttons Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Unclip the right end of the middle trim: 步骤 1 中的图像 2,2
      • Disconnect and power down your controller before you begin.
      • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
      添加评论
    2. Sony DualSense Controller Buttons Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Unclip the lower-right edge of the middle trim: 步骤 2 中的图像 3,3
      • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
      询问修复机器人
      添加评论
    3. Sony DualSense Controller Buttons Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Unclip the left end of the middle trim: 步骤 3 中的图像 2,2
      • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
      询问修复机器人
      添加评论
    4. Sony DualSense Controller Buttons Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Unclip the lower-left edge of the middle trim: 步骤 4 中的图像 3,3
      • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
      询问修复机器人
      添加评论
    5. Sony DualSense Controller Buttons Replacement, Remove the middle trim: 步骤 5 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Remove the middle trim: 步骤 5 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Remove the middle trim: 步骤 5 中的图像 3,3
      • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
      • Lift the middle trim over the joysticks to remove it.
      询问修复机器人
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the L1 button: 步骤 6 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Remove the L1 button: 步骤 6 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Remove the L1 button: 步骤 6 中的图像 3,3
      • With one hand, grip the controller and use your thumb to hold down the left trigger.
      • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
      • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
      添加评论
    2. Sony DualSense Controller Buttons Replacement, Remove the R1 button: 步骤 7 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Remove the R1 button: 步骤 7 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Remove the R1 button: 步骤 7 中的图像 3,3
      • Repeat the previous step to remove the R1 button.
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the rear case screws: 步骤 8 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Remove the rear case screws: 步骤 8 中的图像 2,2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
      添加评论
    2. Sony DualSense Controller Buttons Replacement: 步骤 9 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 9 中的图像 2,2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
      添加评论
    3. Sony DualSense Controller Buttons Replacement, Separate the rear case: 步骤 10 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Separate the rear case: 步骤 10 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Separate the rear case: 步骤 10 中的图像 3,3
      • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
      • Use the point of a spudger to release the two clips on either side of the headset jack.
      询问修复机器人
      添加评论
    4. Sony DualSense Controller Buttons Replacement: 步骤 11 中的图像 1,3 Sony DualSense Controller Buttons Replacement: 步骤 11 中的图像 2,3 Sony DualSense Controller Buttons Replacement: 步骤 11 中的图像 3,3
      • Tight plastic clips secure the left and right edges of the rear case.
      • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
      • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
      添加评论
    5. Sony DualSense Controller Buttons Replacement: 步骤 12 中的图像 1,3 Sony DualSense Controller Buttons Replacement: 步骤 12 中的图像 2,3 Sony DualSense Controller Buttons Replacement: 步骤 12 中的图像 3,3
      • Repeat the previous step on the right edge to release its clips.
      添加评论
    6. Sony DualSense Controller Buttons Replacement: 步骤 13 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 13 中的图像 2,2
      • Lay your controller upside down so the joysticks are on your work surface.
      • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
      询问修复机器人
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the rear case: 步骤 14 中的图像 1,1
      • Remove the rear case.
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Disconnect the battery: 步骤 15 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Disconnect the battery: 步骤 15 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
      • Grip the connector, not the wires, when disconnecting.
      添加评论
    2. Sony DualSense Controller Buttons Replacement, Remove the battery: 步骤 16 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Remove the battery: 步骤 16 中的图像 2,2
      • Lift the battery straight out of the battery bracket.
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the lower microphone: 步骤 17 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Remove the lower microphone: 步骤 17 中的图像 2,2
      在这个步骤中使用的工具:
      • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
      添加评论
    2. Sony DualSense Controller Buttons Replacement, Remove the battery bracket: 步骤 18 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Remove the battery bracket: 步骤 18 中的图像 2,2
      • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
      询问修复机器人
      添加评论
    3. Sony DualSense Controller Buttons Replacement: 步骤 19 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 19 中的图像 2,2
      • Lift the battery bracket out of the motherboard.
      添加评论
    4. Sony DualSense Controller Buttons Replacement, Disconnect the right trigger assembly: 步骤 20 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Disconnect the right trigger assembly: 步骤 20 中的图像 2,2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      • Do not completely remove the ribbon cable yet.
      添加评论
    5. Sony DualSense Controller Buttons Replacement: 步骤 21 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 21 中的图像 2,2
      • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      • Remove the ribbon cable.
      添加评论
    6. Sony DualSense Controller Buttons Replacement, Disconnect the left trigger assembly: 步骤 22 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Disconnect the left trigger assembly: 步骤 22 中的图像 2,2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
      询问修复机器人
      添加评论
    7. Sony DualSense Controller Buttons Replacement: 步骤 23 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 23 中的图像 2,2
      • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
      添加评论
    8. Sony DualSense Controller Buttons Replacement, Disconnect the upper microphone: 步骤 24 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Disconnect the upper microphone: 步骤 24 中的图像 2,2
      • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
      添加评论
    9. Sony DualSense Controller Buttons Replacement, Disconnect the touchpad: 步骤 25 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Disconnect the touchpad: 步骤 25 中的图像 2,2
      • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
      添加评论
    10. Sony DualSense Controller Buttons Replacement, Lift out the motherboard: 步骤 26 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Lift out the motherboard: 步骤 26 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Lift out the motherboard: 步骤 26 中的图像 3,3
      • Carefully guide the joysticks through the front case and lift the motherboard out.
      • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
      • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the light guide: 步骤 27 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Remove the light guide: 步骤 27 中的图像 2,2
      • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
      添加评论
    2. Sony DualSense Controller Buttons Replacement: 步骤 28 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 28 中的图像 2,2
      在这个步骤中使用的工具:
      • Use a pair of tweezers or your fingers to remove the light guide bracket.
      询问修复机器人
      添加评论
    3. Sony DualSense Controller Buttons Replacement: 步骤 29 中的图像 1,2 Sony DualSense Controller Buttons Replacement: 步骤 29 中的图像 2,2
      • Use a pair of tweezers or your fingers to remove the light guide.
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the speaker: 步骤 30 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Remove the speaker: 步骤 30 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Remove the speaker: 步骤 30 中的图像 3,3
      在这个步骤中使用的工具:
      • Use a pair of tweezers to remove the speaker from the midframe.
      • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
      添加评论
    2. Sony DualSense Controller Buttons Replacement, Remove the midframe: 步骤 31 中的图像 1,2 Sony DualSense Controller Buttons Replacement, Remove the midframe: 步骤 31 中的图像 2,2
      • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
      询问修复机器人
      添加评论
    3. Sony DualSense Controller Buttons Replacement: 步骤 32 中的图像 1,3 Sony DualSense Controller Buttons Replacement: 步骤 32 中的图像 2,3 Sony DualSense Controller Buttons Replacement: 步骤 32 中的图像 3,3
      • Carefully lift the midframe and motherboard up and out of the front case.
      • Be careful not to strain the vibrator motor wires.
      • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
      添加评论
    1. Sony DualSense Controller Buttons Replacement, Remove the conductive silicone rubber: 步骤 33 中的图像 1,3 Sony DualSense Controller Buttons Replacement, Remove the conductive silicone rubber: 步骤 33 中的图像 2,3 Sony DualSense Controller Buttons Replacement, Remove the conductive silicone rubber: 步骤 33 中的图像 3,3
      在这个步骤中使用的工具:
      • Use a pair of tweezers or your fingers to remove the three conductive silicone rubber pads from the inside of the front case.
      • The buttons are resting loose in the front case.
      添加评论
    2. Sony DualSense Controller Buttons Replacement, Remove the buttons: 步骤 34 中的图像 1,1
      • Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
      添加评论
结论
取消:我没有完成这个指南。
48等其他人完成本指南。
Sam Omiotek
于02/25/19注册
99,834 声望
创作了289篇指南
6指南评论
good step by step list. easy to follow. thanks
Marc Lazure - 回复 分享
Wayyyyy too much Daddy-O
Guy - 回复 分享
Thanks for the awesome guide. I fixed my sticky buttons.
Jan - 回复 分享
You can skip step 25 and 26 as it is not necessary to remove them.
someonenotyou - 回复 分享
Thanks, you make me economizes 70€, my issue were the directional arrows up, I just followed the instructions clean everything, then test it, is work perfectly! I recommend! For every person read this comment, take your time, no need to force on anything Japanese people think perfectly about it!
benjamin kumi - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 95
过去 7 天: 759
过去 30 天: 3,430
总计 171,813
