跳转到主内容
加入维修社区 - 创建账户
Pontiac Grand Am 是 Pontiac 生产的一款中型(后来演变为紧凑型)轿车。1999-2005 年款是 Pontiac Grand Am 的最后一代。
Where is the Oxygen Sensor?
Hello, i was trying to fine where to place my oxygen sensory in my 2000 Grand am can you help me thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
How do i know which oxygen sensor is bad and how
完成的
添加一条评论
4个答案
已选择的解决方案
All 99+ models are equipped with two oxygen sensors. One upstream Oxygen sensor, and one downstream Oxygen sensor. The upstream oxygen sensor is mounted in the exhaust before the catalytic converter, and the downstream one is mounted in the exhaust after the catalytic converter. There is some great info on how to check and replace the Oxygen Sensor right here. Hope this helps, good luck.
这个答案有帮助吗?
得分 14
添加一条评论
It is threaded into the exhaust manifold on the rear side of the engine. You will need a special socket that fits over the sensor and the wire lead.
这个答案有帮助吗?
得分 4
1条评论:
A link to that special socket would really improve this answer.
完成的
添加一条评论
The downstream is a ##&&% considering where it is and on my 01 Grand Prix the thing sits about 6 inches from the ground your best bet would be to use a hammer break the bad sensor then socket it off I did it with my upstream last night also unhooking the exhaust helps a bunch with reaching the sensor I'm in the position to where I already wasted money on it but I feel it would be better to put a straight pipe on it and eliminate the sensor completely
这个答案有帮助吗?
得分 2
添加一条评论
You could get two O2 sensor socket at any automotive parts place
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dora 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 19
过去 30 天: 67
总计 62,725
