跳转到主内容
加入维修社区 - 创建账户
Fan thermal Test: FAILED
Fan thermal Test: Failed,
Failure ID: MCSFXD-B51CGQ-MFPX0J-J6FK03
Please how do I go about it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@kelvinnana79347 most common issue with that "Fan thermal Test: Failed" is a bad fan or heatsink (bad thermal paste can cause this) as well. I suggest you check and (clean your fan) heatsink. Replace the thermal paste and if need be, the fan as well.
If you should still have issues with that after then check for a BIOS update (it is possible that there is "miscommunication"). Since iFixit does not yet have any guides for this laptop use the HP Pavilion Gaming 15 Maintenance And Service Guide instead.
To replace the thermal paste use something like this generic guide 如何涂散热膏
While you work on your laptop, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kelvin Nana Kwasi Anson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 21
总计 274
