跳转到主内容
加入维修社区 - 创建账户
HP 14-dq0051dx 是 HP 14 系列笔记本电脑,于 2019 年发布。
Upgrading the hard drive?
I actually have a HP 14-dq0001dx wit 64gb eMMC SSD and 4 GB RAM. Is is possible to upgrade the hard drive to a larger drive? If so, where is the hard drive locate? Is it under the motherboard?
Thank you,
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
I took a look at the guide to access the motherboard and HP stripped everything that could be used away - it looks like they engineered a stripped out board just for these machines. Now that said the reason I looked into this is at one point HP used a SATA interposer which allowed for an upgrade, but as they built these more formally it's being done like every other eMMC laptop. @oldturkey03 is right - can't be done.
If your had the slot it would be here:
这个答案有帮助吗?
得分 3
添加一条评论
@bill75092 it can't be upgraded, your eMMc drive is part of the motherboard. Furthermore, any of the other ports (SATA;M.2) have been disabled and can't be enabled. You are stuck with the 64GB.
If you do want to work on it and verify any of this, use the Maintenance And Service Guide HP14
这个答案有帮助吗?
得分 1
添加一条评论
From the service manual, which you can get from HP site, you can change the RAM to an 8GB module, but to change the main drive (not an HDD) memory you would have to change the system board.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 18
过去 30 天: 88
总计 2,010
