跳转到主内容
Repair guides and support for Canon's EOS Rebel XSi. This is a DSLR camera with a 12.2 MP sensor released in 2008. Also known as the EOS 450D and the EOS Kiss X2.
20 个问题 查看全部
Why does my screen flicker like this after about 10 seconds?
Why does my screen go like this about 10 seconds after turning it in, and then soon after the camera shuts down and sometimes gives an err99? Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @inglewood
Check if the procedures shown in this video will fix the problem or not.
完成的
Thanks. Done all that. After “rebooting” the camera, same thing happens. Every time.
完成的
添加一条评论
1个答案
最有帮助的答案
@inglewood the err99 is a very generic error code. It can show up when there is a lens incompatibility, a battery problem, a shutter problem or bad contact between the body and the lens. I don't think it is related to your LCD issue. That actually looks like a bad LCD display. It will start to get double vision when it warms up. I suggest you consider replacing the display and while you work on your camera, make sure that the ribbon cable and connectors are not bend or corroded. Canon EOS Rebel XSi LCD Screen Replacement
这个答案有帮助吗?
得分 1
2条评论:
Thanks OldTurkey. I ‘ve ordered the lcd. I noticed that the flex cable joining the power board to the main motherboard has two black (maybe burnt) places where it goes into the plug on the motherboard. Doesn’t look good.
完成的
@inglewood hopefully its just the LCD and not the connector or even worse. Anyhow, keeping my fingers crossed that a new lcd will fix this.
完成的
添加一条评论
添加你的答案
Inglewood 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 26
