跳转到主内容
The HTC 7 Surround is a smartphone created by HTC running on the Windows Phone operating system.
7 个问题 查看全部
Why is my HTC Surround not turning on?
I have a HTC Surround, it's in pretty good condition and has never given me any problems. All of the stickers on the phone are still white, I do not think there is any water damage, however the phone does not turn on. I tried reinserting the battery repeatedly, and no luck.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Use a multimeter and test the battery. If no juice, replace it.
这个答案有帮助吗?
得分 2
12条评论:
There was a charge on the battery, as well as 2 random parts on the phone. What should I do know?
完成的
what exactly are you referring to when you say a charge on the battery. You checked the voltage? What did it show? What 2 random parts had a charge on it?
完成的
The charge on my battery was 1229mAh
On the phone, I attached the ends to the battery fits in (like the 4 spikes). I attached 2 spikes on each end got a REALLY small amount. Basically nothing
完成的
The charge should not have been measure in mAh. mAh is the capacity of the battery, and is the product of current and time, so your 1229mAh battery can supply 1.229A for one hour. If you connected a voltmeter to the battery and "basically" got"nothing" replace the battery and make sure your battery contacts are clean
完成的
I got the 1.229A for the battery. When I connected it to my bare phone i got nothing. And when I connect to my charger, the phone still doesn't turn on? D:
完成的
显示更多的7条评论
添加一条评论
me i ask also becoz if i charge the phone then it will but the moment i going to open it, i can't
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anand Matta 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 6
总计 1,882
