跳转到主内容
许多佳能数码相机和胶片相机的修理和拆卸指南。
Black screen when turned on
My "Canon PC1060 Digital Ixus i" show a black screen when i turn it on, the problem is not correlated to the screen (i suppose) because when i open the menu section it work perfect! the same for the lens or the flash parts, what can i do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@marcoiodice since you can see the menu, it is unlikely that this is an LCD issue. Tell us what happens when you shoot an image. If it is saved in black as well, then the issue could be a stuck shutter or a failed sensor/lens mechanism. When no image is displayed although the menu screen is displayed:
•OPTICAL UNIT is defective (the shutter of the lens block is not open, etc.) Looks like the PC1060 was predominantly a Japanese version, it should be the same camera as a PowerShot SD10.
This Disassembly Canon PowerShot SD10 should work for your camera. Just take your time when you disassemble it, just in case there are differences in the construction. You do want to focus on the optical block.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Marco Iodice 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 15
总计 168
