Why my TV is stuck on standby
When you plug it only the red colour shows on the standby button
@colonel62932 the power LED shows that the power supply provide standby voltage the mainboard. Once the mainboard receive a signal from the IR board to turn on, it signals the power board to do so. In your case, this could be a bad main board or a bad IR board.
Time to unplug it, and to remove the back cover. Then take a look for any obviously damaged looking parts on those boards. Take a couple of good pictures of the boards and post those with your Question. That way we can see what you see and hopefully guide you further,
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 162
@colonel62932 verify that your TV is a Hisense 32H4C
由 oldturkey03 完成的
