跳转到主内容
iFixit 使用 cookie 来增强网站功能、分析流量和个性化广告。使用本网站即表示您同意我们的 cookie 使用和隐私政策
The Nikon Coolpix 995 a 4 x optical zoom, 38 - 152 mm with rotating handle was released in 2001.
3 个问题 查看全部
How to completely open the camera, both halfs.
I dropped the camera into the water recently, as in the whole body and there's water under the shell, for the most part the memory and battery carpartments were dry but there water under the view finder and I want to get it out before I try to see if the camera still works. I got the lcd side open but need the other side too.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
This is not SPAM but was deleted as spam
Esto no es SPAM pero fue borrado como spam
Dies ist kein SPAM, wurde aber als Spam gelöscht
这个答案有帮助吗?
得分 0
添加一条评论
@flaviob20996 for the complete disassembly, repair and part etc. go Nikon Coolpix 995 and under Documents you can now get the proper literature (iFixit Magic:-) It'll tell you all you ever wanted to know about your camera.
When you do have it apart and since it did get water damaged, treat it like any other water damaged device. Clean the whole board, connectors and all with +90% isopropyl alcohol. Follow this guide It was written for an Apple 3G iPhone but all the points are still pertinent to your camera. While you clean your boards, check for any obvious damage, like burned or missing components etc. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your camera and reevaluate.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Flávio B. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 130
