跳转到主内容
加入维修社区 - 创建账户
第九代 Chevrolet Impala 于 2006 车型年首次亮相。该代 Impala 为前轮驱动四门轿车,搭载多种 V6 发动机。车队版本车型以“Impala Limited”之名持续生产至 2016 年。
Driver side front window
Driver side front window won't go all the way up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Potentially a broken hoist mechanism for the car window. Refer to year and model relevant owner's guide to find if it is described there.
由完成的
添加一条评论
2个答案
最有帮助的答案
@cammyvonre52411 we will need to know your exact model year and if it is a two door coupe or a four door sedan. There are differences in the power window wiring. This is assuming that you are referring to power windows.
If this is just an issue of the window freely moving down and then back up just not going all the way up, then it is most likely a regulator assembly issue. To check the wiring and to work on the window regulator, use the Doors Manual Page 62 tells you how to test the power windows (just in case it is a motor issue) and Page 199 shows the removal/installation of the window regulator.
Once you have the trim off and can see the regulator, take a couple of pictures that show the regulator etc. and post those with your Question. That will allow us to see what you see. We can then try and help you to determine if you have to replace it or if it can be fixed.
在已经存在的问题里加入图片
这个答案有帮助吗?
得分 1
添加一条评论
There could be a few issues:
1. Check your window switch in different positions if your window is rolling up or down slowly or has intermittent stops replace the switch
2. Check the window track it may need to be greased or have something in it blocking your window.
3. After those two check your window regulator and your window motor if either one has not enough power it will keep the window from rolling up.
If you need any kind of help with diagnoses let me know and I'll post step by step how to do each.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cammy Vonrekowski 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 40
总计 815
