跳转到主内容
This is a point-and-shoot camera created by Canon in 2011.
12 个问题 查看全部
Fixes for "Wrong Flash Position, Restart the camera"
I keep getting this error and It would be too expensive to send to canon. What might be malfunctioning here?
P.S. I opened the camera and cleaned it's gears on the flash and it doesn't still seem to work
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@zhyctnani seems to be a common issue with this camera try this "I managed to fix it myself by first turning off the camera and fully pushing the flash all the way down. That did not yet solve the problem. Then I did a reset as described earlier in this thread. Again, no change. Finally, I used a fingernail to pull the flash mechanism all the way up, again while the camera was off. I then turned the camera on and turned it off again, and it retracted. Now it extends and retracts as expected, and with no more errors." from here while we keep looking for a viable solution.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Zhyct Nani 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 88
总计 1,240
