跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
How can I repair the speaker connection to the logic board?
While replacing the batter I accidentally snapped the connector for the right speaker to the logic board. The left speaker works fine I just want to know if bins possible to solder the pins back in the board or not. Plus I would love a suggestion as how to do it.
Here’s a picture
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Well it could have been worse!
You did manage to rip-off one pad so this will take a trace patch. This will take some finesse by someone with good micro-soldering skills and access to the replacement part.
这个答案有帮助吗?
得分 0
添加一条评论
@scottlieberman the connector is a Molex 78171-6006 Molex 78171 6006 Speaker Connector Not sure where you are located but you can always try Mouser.com or Farnell.com as well as many others. Oh yes, even ebay.com has those
As was previously mentioned, the pads etc all look still pretty usable but still require one jumper. Now to solder on the Apple boards needs a bit of practise, but it's not rocket science. Just use a different type of scrap circuit board to get some feeling for your soldering equipment etc. first. The parts are large enough that you do not need a microscope. One of those geeky looking visor magnifier is absolutely sufficient.
The connector repairs the same way as the fan connector. Use something like this video to see how that is done. You can also check YT for northridgefix about how to perform boardlevel soldering. Again, it's not rocket science just needs decent tools and practice.
To apply a jumper simply just means soldering a thin wire from the closest point to the torn pad to connect to the new connector. Post another image just this time zoom out so we can see the surrounding components.
If the task is too daunting and you need to send it off, there are a few fixers that we can recommend since they are known to us. Just let us know what country and possible region you reside in.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Scott Lieberman 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 18
总计 263
