跳转到主内容
The Canon PowerShot A710 IS is a compact and feature-packed DSLR released by Canon in 2006. It also comes with numerous accessories to make it an even more reliable machine to take on-the-go.
2 个问题 查看全部
Camera won’t turn on
I have recently replaced all the batteries and the compartment closes well but my camera still won’t turn on. I can’t find any camera repair near me and idk what to do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@ellianavannoort could be an issue with the DC circuit on your main board. There should be 2 fuses on it, one being the power fuse. It may have failed. Time to take it apart and to check things out.
Since iFixit does not yet have a guide for this, use something like this video (terrible music, turn the volume down ;-) it is for a A720 but should be similar enough to get you into your 710. Once you have it opened up and are at the circuit boards, take a couple of pictures of those boards. Post them with your question so that we can see what you see. We can most likely assist you further once we see what you have going on there.
While you work on your camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
这个答案有帮助吗?
得分 0
1条评论:
Good suggestion. However, If I find that there is a problem with the power fuse, where do I get a replacement? The camera is obsolete according to canon.
完成的
添加一条评论
添加你的答案
Elliana Van Noort 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 3
过去 30 天: 10
总计 160
