跳转到主内容
Internal hard disk drive not found and No bootable devices.
After power on there is error showing on display -
internal hard disk drive not found
to resolve this issue, try to reseat the drive.
No bootable devices--strike F1 to retry boot, F2 enter setup Menu, F5 enter PSA
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@abhishekku14745 sounds to me like you lost your boot drive. I would try and access the BIOS and check if the BIOS can "see" your drive. If it can, it is possible that your OS got corrupted and may need a reinstall. If it does not see it, then it is most likely a failed drive. To get into it, press F2 at the boot splash screen to enter the EFI setup. Look around and see if you can find your drive. Check for Boot order etc.
You want to set your boot order to a USB drive. You will have to make a USB drive bootable and use that to start your computer, then try to restore your drive with that. Since you did not tell us which OS (I assume Windows x.xx) we will have to wait to see what you discover.
这个答案有帮助吗?
得分 1
添加一条评论
My keyboard is very fcked right now it isnt registering some keys right so the answer will have to be like this ok
Your hard drive could have been broken meaning you lost all your data but thats very unlikely
You probably lost your boot drive
You should take your computer to your local technician and see what they can do to fix the issue
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
ABHISHEK KUMAR 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 170
