跳转到主内容
Repair information and troubleshooting help for the Acer Aspire ES1-111 laptop.
Why is my laptop showing no bootable device
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
@inoshineed29688 sounds to me like you lost your boot drive. Your laptop uses a 32 GB SSD (I suspect an eMMC drive) as internal storage. I would try and access the BIOS and check if the BIOS can "see" your drive. If it can, it is possible that your OS got corrupted and may need a reinstall. If it does not see it, then it is most likely a failed drive. To get into it,press F2 at the boot splash screen to enter the EFI setup. Look around and see if you can find your drive. Check for Boot order etc.
You want to set your boot order to a USB drive. You will have to make a USB drive bootable and use that to start your computer, then try to restore your drive with that. SInce you did not tell us which OS (I assume Windows x.xx) we will have to wait to see what you discover.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Inoshine Edward Dimowo 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 24
总计 310
