跳转到主内容
An Android smartphone made by vivo.
Why my phone restart automatically
My phone switch off and on itself
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
Blank screen doesn't start
完成的
@jag72387 not enough information to help you with that. Be more descriptive.
完成的
添加一条评论
3个答案
最有帮助的答案
@nitingarg95976 you didn't tell us what you have checked and what you have tried. A bad battery can cause frequent reboots. Start by replacing your battery. Use something like this video to do that.
Of course this assumes that you did the usual software/firmware solutions, like a hard reset (save all your files because they will get deleted), starting in safe mode, updating your firmware, clearing your cache and making sure there are no rogue apps running it the background.
这个答案有帮助吗?
得分 1
添加一条评论
If your phone restart automatically and frequently there is battery issue. The battery of Vivo s1 and s1 pro is repairable. Just remove the fuse and jump it with soldering. It wil help 1000%
这个答案有帮助吗?
得分 1
2条评论:
@rishisaini your answer needs a bit more of an explanation. Why would you remove a fuse (Which fuse?) and apply a jumper to replace the battery?
完成的
The whole process is explained in this video
https://youtu.be/ImOLtiE0yr8?si=pTfbiYLh...
完成的
添加一条评论
Battery problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
NITIN GARG 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 223
总计 2,415
