跳转到主内容
The HP Elitebook Folio 9480m was released on July 4, 2014. The 9480m model can be identified by model number J5P80UT.
9 个问题 查看全部
Laptop Show charging but battery % not increase
My Laptop show charging but battery it not increase the battery power Can this is Charging IC Problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
2条评论:
pls my laptop elite book folio 9470m anytime i open the laptop, like while raise the laptop it display white if i move it back a little it display normal
what could be wrong with it is it the flex?
完成的
Charge cannot fast battery
完成的
添加一条评论
1个答案
@abdullah9805 yes it can be. The very first thing you want to do is to change your battery. That can also be the reason for slow charging. The Battery control module is commonly what regulates the charging. Download the maintenance and service manual from here to work on your laptop.
This HP Elitebook Folio 9480m Troubleshooting will help with some quick troubleshooting.
While you work on your computer, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abdullah 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 206
