跳转到主内容
How to repair my screen
the screen is spoilt and some parts cannot display images as its showing a crack
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
You will have to replace the display panel, which is a rather simple job but may take some time depending on your device configuration. The following is a general idea of the steps needed to do that, though I do not know your exact device, only similar ones, so take your time, take care, and make sure you are careful not to damage anything. As always, follow proper safety procedures for working with electronics such as grounding yourself and disconnect any power plugs from anything you're working on.
Here is a video showing the procedure on a similar model: https://www.youtube.com/watch?v=WCU7zolC...
Please note that while this video does show a screen replacement, I cannot recommend his methods. He does not disconnect the battery or follow other safety procedures, leading to a much higher chance of short circuit or damaging the laptop.
Written below is the full procedure with the safety steps before the actual removal of the screen. This is the method I will recommend, but doing any repairs is always at your own risk, following safety procedures or not.
First step is to take off the bottom panel.
Then you will disconnect the battery immediately.
After that, find the display connectors (any ribbon, cord, or wire that is coming through the hinges from the screen to the motherboard). These can include ZIF connections, press connections, coaxial connections, or sometimes others. Disconnect them all.
Then unscrew any screws holding the hinges in.
Removing the assembly now is a matter of opening the lid to the right angle and gently separating the display assembly from the hardware.
With the assembly removed, Remove the bezel (it is held on by adhesive, and should be easy enough to remove with an opening pick or something similar).
You can now unscrew the screen, which should be held in place with one screw in each corner.
Finally, disconnect the other end of the ribbon cable that connects into the bottom of the screen, and remove anything else holding it in place. You have now successfully removed the display panel from your laptop.
With the screen completely removed, find the part number on the back. It may be printed directly on the metal or on a sticker. There may be multiple different strings of characters printed in various places back there. Just google those strings of characters one at a time until one gives you results for vendors selling the screen that you need. That is your display model number.
There will assuredly be multiple vendors selling the screen, and you can choose based on price, shipping to your country, time to delivery, or general trustworthiness. They will typically be all relatively close in price, and any vendor advertising a part for under half price everyone else is almost assuredly a scam, so avoid them.
Order the display from your chosen vendor. and when it arrives, install it by following the above steps in reverse.
这个答案有帮助吗?
得分 1
2条评论:
@oldturkey03 You are always better at finding the official documentation than I am. I couldn't find that in a quick search, so I did my best to write a generalized version of the procedure, but 100% definitely @onesmusboke you should follow the guide linked here as it outlines all the safety procedures and documents exact screws and etc. instead of my vague version that may have you miss something important.
完成的
@erelectronics you do it so well. Don't stop letting people know how to do those repairs. Your input is absolutely valuable and adds much expertise to any repair. Well done Sir! ;-)
完成的
添加一条评论
@onesmusboke besides the excellent answer provided by my colleague @erelectronics I suggest you download the Maintenance manual for your computer from here Page 105 will tell you how to replace the display assembly according to HP
That same manual also shows the part numbers for a replacement screen. Use that to do an online search to find a vendor that is appealing to you.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Onesmus Boke 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 447
