跳转到主内容
加入维修社区 - 创建账户
新 Nintendo 3DS 是 3DS 产品线中第一款大幅更新的迭代设备。在日本于2014年10月发布,北美市场于2015年9月发布。2015款 3DS 改进 3D 显示性能,全新 C 摇杆,内置 amiibo 读写功能,以及全新的4肩键配置。
Possible hinge warping when replacing screen lens
Hi, want to replace the screen lens but I'm not sure if using a hair dryer to loosen the old lens will cause the hinge to warp and break, what would be a good way to prevent this from happening, or will it be fine without any need for prevention.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
@bruceblack44051 hopefully your hair dryer does not get that hot. Anyhow, always keep it moving, don't blast all the hot air at one spot. The trick here is to create an even warm area to remove any adhesive etc. If you are still concerned, cover the hinge area with some aluminum foil and you should be okay ;-)
这个答案有帮助吗?
得分 1
1条评论:
I'll set the dryer to a lower setting when I use it to he sure, and thanks for your response appreciate it 👊🏼
完成的
添加一条评论
I am posting this to supplement the response @oldturkey03 left. There are a few hairdryers on the market to never, ever use for a case like this I have used on things like data recovery operations like an LG G4 509K, and Samsung as well as pre good design Pixel adhesive like the 3 XL: The Conair 1875. DO NOT USE IT, IT GETS THAT HOT. It will probably melt multiple parts if you're not careful! If it can get me into a P3/P4 series (known for terrible adhesive), it gets that hot. I won't even use it for battery adhesive unless I am replacing that battery; I seen all I needed to see after I pulled off a data recovery operation with a hairdryer... I don't want to know the risk level; it probably permanently compromised my old LG G4's battery since it had to be installed to turn on to the point I wouldn't even want to give it to a friend who knows I exposed it to that thing.
A good rule of thumb is if it's 1,000+ watts, probably too hot unless it's a "styler" design like the Conair 1875 styler. This is the bad one: Conair 1875, avoid; gets hot enough to melt solder, this is BAD FOR PLASTIC, but this one is fine: Conair 1875 Styler, less risky but be careful.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Bruce Black 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 514
