跳转到主内容
issues when upgrading HD?
Decided to upgrade my internal Hd from 160GB to new Hitachi travelstar 7k500...i have read tons of people complaining on several forums that they have experienced strange beeps from newly upgraded hd as well as intermitting freezes and beachballs...somebody suggested this might have something to do with sata II capability and the 1.7 efi firmware update...does anybody know if there's a definitive answer to this...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
thanks a lot, everybody...i really appreciate your help...the thing that worries me most is the fact that I wish NOBODY would ever have to worry about upgrading their HD in a Mac!!!isn't that why we all choose Apple? because we don't want trouble of this kind...? Come on i think it's crazy to have to rollback your EFI firmware or worst replacing a data cable just to replace a HD drive...I think Apple should give us a definite answer to what the problem really is, so that we don't have to spend time and money finding a solution for this...
Sorry for the harsh words but i think this thread shouldn't even have been started in the first place, these kind of ridiculous problems should not even arise...
完成的
I agree, Apple's not really used to admitting blunders. Luckily, we have forums like these and great people that band together for solutions.
完成的
添加一条评论
8个答案
已选择的解决方案
I've been upgrading hard drives since I put one in a Mac+ in 1986 and never heard of any of the problems you describe. I really wouldn't worry about rumours. We have professionals here to help you with your installation. Here's how to do it: MacBook Pro 13“一体式2009硬盘更换
After it's in, start up from your system disk, go to Utilities and format and partition the drive. Then install the system and restart. The only time I've ever had problems with new hard drives was when the had been formatted on a PC first.
这个答案有帮助吗?
得分 5
3条评论:
Here's a thread on that drive in the MacBook: http://forums.macrumors.com/showthread.p...
完成的
If mactech's going to voice a favorite so will I. I like the Western Digital 7200 Scorpio Black. It runs a little hotter but is faster and I've never seen a failure.
完成的
Yeah but you guys have to remember that these are newer products which the average technician has never even seen at his shop. The posters problem is affecting many-many people.
完成的
添加一条评论
最有帮助的答案
The only time I got beeps out of a hard drive is when I was using some software to clean up a computer systems software and when the computer booted from the disk I would get a beeping from the hard drive and it was not able to be accessed. I tried a different version of the software and all was well.
Each of us who work on computers on a regular basis tend to like one brand over another. I like Seagate drives better than Hitachi. The following link is for one that they sell here at iFixit. In my own computer I use One HP and Two Seagate drives. Good product and good warranty. But most any SATA drive will work fine in your computer.
http://www.ifixit.com/Apple-Parts/500-GB...
Long story short. Mayer has been doing this for a long time. I have been doing this for a long time. Both of us do it for a living. We contribute here to help those how ask. iFixit provides this forum for you and others to ask and receive answers. You need to decide who to listen to. No things do not always go as planned. But those are not the norm. In 16 years I have only had One computer with the Beeping hard drive and it was one put in by Apple when the computer was new. It is owned by an Ad Agency and works fine except with that one piece of software.
Good luck and do not be worried. I give you high marks for getting out there and doing your own stuff. If more folks would do that the cost of taking it in to fix may drop.
这个答案有帮助吗?
得分 5
2条评论:
Nice answer +
完成的
完成的
添加一条评论
Sorry but the problem DOES exist.
Indeed if you check on Apple System Profiler you'll see that the factory installed HDD as well as the ODD are both running at SATA 1.5 Gbps even being able to run at 3 Gbps.
I put a new hard disk and after transfering a couple of gigabytes it stuck.
I booted on Linux and tried the same, after 5 seconds of transfer the bus reset and the Linux kernel instructed the controller to link at 1.5Gbps, then it transfered 320 Gb of data without a single fail.
I downloaded the drive's tool from manufacturer (Samsung), run it on a PC and forced the disk to link always at 1.5 Gbps and now it works flawlessly on the MacBook Pro.
This is a known problem, that's why Apple drives come forced to 1.5 Gbps.
Regards,
Natalia Portillo
Apple Certified Macintosh Technician
这个答案有帮助吗?
得分 2
1条评论:
Natalia as an Apple Certified Macintosh Technician you must know/realize/understand/comprehend that Apple products are not built or designed to be upgraded in any manner not prescribed by Apple. Apple products are fine tuned animals not tested nor meant to have foreign products installed in them. If they were you'd have a PC. To the best of my understanding Apple has done it's best to not become a common PC. Perhaps Jaguar, Bentley, Porsche should build their products to accept upgrades with GM parts. But then I guess you could just go buy a GM and save a TON of money. Without breaking the law you don't get the Apple operating system without the Apple hardware. I have read about this issue in several forums. I understand that on several models of the MBP that running the right firmware with the right operating system the problem goes away. People need to quit upgrading their Apple products without researching what they want to do first. People making uninformed decisions almost always get hurt.
完成的
添加一条评论
Andrea, you're not alone in that problem. I have read hundreds of posts. about this issue on other threads. It's affecting most new models of Pros. If I were you, I would try the EFI rollback or replacing the data cable which has solved the problem for many people.
这个答案有帮助吗?
得分 1
添加一条评论
Sorry but Apple's policy has been for a while to allow end-users to upgrade their HDD and RAM without breaking any warranty. This is prescribed by Apple, and guides are provided in their support page.
Even Genius Bar employes guide customers through the procedure (depending on the Store).
Unfortunately this is not a simple incompatibility problem, but a severe bug in the chipset design by NVIDIA, indeed a bug I've seen in all NVIDIA SATA controllers from the nForce 4.
All manufacturers do have bugs, it's usual, normal, expected, Apple is not free from errors, they are humans.
But here the problem is indeed NVIDIA, that has Macintosh users quite used to bugs.
The ONLY way to upgrade the hard disk, unluckily, is to force it to the slower 1.5 Gbps link. Even using an Apple certified drive will fail if the disk is not forced (like for example, requesting a newer drive shared by another MBP model).
Saying this is a rumor it's more politics than technical truth.
Regards,
Natalia Portillo
这个答案有帮助吗?
得分 1
1条评论:
Yes Apple policy does allow end users to upgrade their HDD and RAM. But anyone doing so must make informed purchases or pay the price. Apple for what ever reason has put the SATA 1.5Gpbs limitation on these products. NVIDIA builds the chips to Apple's specifications. They don't hand Apple what ever they want to. Apple writes the firmware for it's systems. Apple supplies the the SMC and the firmware that operates it. Apple's firmware and SMC are what do not automatically revert 3Gbps drives to 1.5Gbps. This is a firmware and SMC issue, not an NVIDIA's. Anyone reasonably competent with replacing computer hardware would look to see the specifications of what is installed in a system prior to making an upgrade. They would further educate themselves on the limitations of the system they are about to upgrade. They would purchase something within those limitations to upgrade with. Therefor purchasing a HDD that is not 1.5Gbps for these laptops is not a good decision unless you are willing to accept the work around.
完成的
添加一条评论
thanks guys i really appreciate the fastness of your answers...I myself am a long time mac user and have several times upgraded internal hd on PowerBooks and iBooks without problems...but recently i have stumbled upon a couple of discussions on the Apple web site: http://discussions.apple.com/thread.jspa... this one is 130 pages long!!!!!
And:http://discussions.apple.com/thread.jspa...
which would instill doubts to the most competent of Apple hardware expert...
这个答案有帮助吗?
得分 0
1条评论:
I read through several pages of those posts. Looks like the cable. But you're not having those problems, right? If it ain't broke don't fix it.
完成的
添加一条评论
You can see yourself on www.nvidia.com that the NVidia specifications CLEARLY say SATA 3 Gbps. When you have do to a workaround, quirk, whatever you name it, to prevent a hardware failure, it's a hardware bug.
NVIDIA does not make the chipsets up to Apple's specifications. Apple buys the same chipsets you yourself can buy (or Acer, MSI, Gigabyte, say one). Even on PowerPC Macs, the chipsets are off-the-shelf Motorola or IBM chipsets anyone can buy (given enough money and quantities).
If you're competent with replacing computers components, you'll check the specifications of the chipset and see clearly that SATA 3 Gbps is supported, and you'll see that the drives mounted by Apple are SATA 3 Gbps compliant, and question yourself why are they limited to SATA 1.5 Gbps.
Then you'll go to buy, and see yourself that no more SATA 1.5 Gbps equipment is being sold, that all drives you can buy new are SATA II and 3 Gbps. You'll put one, because specifications say it MUST work, all the components are (in theory) compatible, and in practice you'll see the chipset fail.
Again, talking of specifications, if you take a SATA 1.5 Gbps controller it will NEVER link to 3 Gbps (like the MBP's one is doing), because it was made before that protocol was created.
And NVIDIA is not the only one, there are a good chunk of SATA 3 Gbps controllers with some kind of bugs (data corruption at 3 Gbps, data corruption when transferring more than 16 Kb at once, data corruption with NCQ enabled, so on), and none of them tell any of that in their specifications, because that will hurt sales.
Apple designed the MBP with a NVIDIA chipset, and when they discovered the bug it was too late to redesign it with other chipset, and the easiest solution, forcing the link on the drives, was chosen. However Apple committed three fails:
1.- To not inform end users on the "how to upgrade hdd" tutorials
2.- To not inform certified technicians of the quirk
3.- To not make the firmware automatically slow down the link
If you want to continue talking about specifications, go to www.nvidia.com, download the chip datasheet and show us where they say their SATA 3 Gbps controller cannot work at 3 Gbps.
Your positive trolling over Apple is lovely, but it's not the real world.
They have failures, errors and bad decisions, like all of we do.
Regards,
Natalia Portillo
这个答案有帮助吗?
得分 0
2条评论:
With all do respect Natilia. You seem like an intelligent person. But, you do not seem to comprehend what firmware is, nor grasp things on the chip level. Furthermore you do not understand the electronic manufacturing process or the Apple-NVIDIA relationship. Your lack of knowledge in these areas is clear. I never stated that the NVIDIA chip set wasn't designed nor intended to use 3Gbps SATA. I clearly stated that these chip sets as implemented by Apple, with the Apple firmware, have been throttled down to 1.5Gbps. It is the firmware that tells the chip what to do. To date you stand on your certification as the authority. You have provided no proof of your assertions such as Apple suing NVIDIA over Apple's need to add extra steps to the manufacturing process such as locking hard drives to 1.5Gbps because of the problem chip(s). Real world, reality says that would happen. Real world, Apple & NVIDIA are building a stronger relationship. http://www.appleinsider.com/search.php?k...
完成的
[A]"And NVIDIA is not the only one, there are a good chunk of SATA 3Gbps controllers with some kind of bugs (data corruption at 3Gbps, data corruption when transferring more than 16Kb at once, data corruption with NCQ enabled, so on), and none of them tell any of that in their specifications, because that will hurt sales." These things can all be dealt with through firmware & operating system. [B] Please show me something from Apple documenting this next statement. "Apple designed the MBP with a NVIDIA chipset, and when they discovered the bug it was too late to redesign it with other chipset, and the easiest solution, forcing the link on the drives, was chosen." [C] The following pretty much says: Apple doesn't want people to upgrade their Apple products or they would have made it clear how to. "However Apple committed three fails:
1.-To not inform end users on the "how to upgrade hdd" tutorials 2.-To not inform certified technicians of the quirk 3.-To not make the firmware automatically slow down the link."
完成的
添加一条评论
A1278 13.3" MBP
Guys, there ISN'T a door on the back giving access to the battery (don't remove) and the HD for the 13.3" model. You make no mention of this issue nor any acknowledgement that the 13" is different. You have to remove 4 screws from the upper part of the bottom, 2 more from the middle sides and three long and one short screw from the very back near the vents, At that point you can lift the bottom case completely off giving you access the the hard drive. You take off the upper bracing and its two build in screws (torx #6, but don't separate the screws from the bracket, then two screws from the bottom retainer, pull up on the clear tag, and the HD is loose, then carefully pull away the ribbon connector. You then remove the (think of Frankensteins bolts coming out of his neck) bolts Torx #6, from the corners. Place the bolts into the corners of the new drive, switch the ribbon cable you took off the old drive, fit the bottom bolts into their holes, add the two screws on the bottom. The "botls" set first into the bottom square holes with copper connectors, then on the upper part they sit in a "half moon" shape cup where the retainer was, when you add the retainer with its opposite half moon copper hole you complete the "frame" holding the HD. Replace the entire bottom case and your ready to format and transfer info from the old drive to the new.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrea geremia 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 8,637
