简介
转到步骤 1 ↓更换硬盘时,必须将四个定位销(用T6螺丝刀拆下)从旧硬盘换到新的。
你所需要的
修复工具包
本套装包含完成指南所需的所有零件和工具。
配件
1 TB SSD 混合硬盘 (2.5 英寸) (Upgrade Kit)加盟链接在 Amazon 上有售
This kit contains the drive and all tools needed.
500 GB SSD Hybrid 2.5" Hard Drive (Upgrade Kit)$103.994.9
This kit contains the part and tools needed.
工具
Spudger4.9
要重新组装您的设备,请按照该指南并按照相反的顺序重新组装。
571等其他人完成本指南。
由衷感谢以下译者:
100%
笑得像个300斤的孩子正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
16指南评论
I'd suggest using the free software "Super Duper" to clone the hard drive. It worked wonders for me and after the 2 hour clone, I was up and running in 5 minutes!
cmoore22739 - 回复 分享
I wholeheartedly agree. Super Duper! made the task effortless.
danzeitlin - 回复 分享
The T6 torx screws on the side of the existing Hitachi drive fit my Crucial M500 240GB replacement perfectly. Be aware that they were originally installed into the HDD with blue Loctite, so it takes a bit of effort to break them loose.
Thanks ifixit for excellent guidance!
danzeitlin - 回复 分享
What do you do when your laptop doesn't read your new hard drive?
amberscheme - 回复 分享
If your hard drive dosent connect. you might need to change your hard drive connect cable . The second option is that you need a strip to replace your hard drive with DVD rom.
Asim Rafaq - 回复 分享
