跳转到主内容
加入维修社区 - 创建账户
20英寸、23英寸和30英寸铝合金LCD显示器,由Apple于2004年6月推出。型号分别为A1081、A1082和A1083。
Adding a Fuse to Protect Display
The Apple power supply finally bit the dust, it was used on my 30" Cinema Display. I have purchased one of the $20 240 Watt, 10 Amp power supplies to replace it. I would feel much more comfortable using this inexpensive PSU if I could add protection between the display and the power supply. I welcome any advice on how to add a fuse with the goal of not destroying the display should the power supply go haywire.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
@charles218 lets see what the end connectors look like. You can always add a 25 V 8 A inline fast-blow fuse.
这个答案有帮助吗?
得分 0
6条评论:
I am planning on removing the connector from the dead Apple power supply and using it with the new power supply, this way I don't have to cut the display cable. It looks like the fuse would need to go between the recycled connector and the power supply tap.
由完成的 分享
@charles218 yup. Right one the power lead.
由完成的 分享
Is it important that the fuse holders wire be the same gauge or close to the same gauge as the connection wire?
由完成的 分享
@charles218 not on that length. You'll be fine with slightly smaller/bigger leads.
由完成的 分享
Old Turkey, you have been very helpful, thanks! I searched for the past half hour or so for 25 V - 8 Amps without success, nothing comes close, so if you or anyone has any leads on where I can find it, please let me know.
由完成的 分享
显示更多的1条评论
添加一条评论
添加你的答案
Charles Larkins 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 19
总计 516
