跳转到主内容
Repair guides and support for the third-generation 5D, a DSLR camera released by Canon in 2012.
ERROR 30 when I press the shutter
I get error 30 when I press the shutter, The message instructs to turn power off and on again or replace battery. After doing both there is no change, still error 30 however it does record the shot as I can review and see it on screen. So after every shot I take I have to turn it off. However if I shoot video there is no error what so ever.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
My canon 5D make iii
Error 30 fold
完成的
@rhiva perform the steps given in the original answer and let us know what the outcome was.
完成的
添加一条评论
1个答案
jackfuller Err 30: Shutter malfunction. Just like anything else with these cameras, try another lens to see if it still gives you the same error. If so it could be mechanical error with the shutter or it could be with any of the flex cable etc. This manual Eos 5d starting on page 127 will help you with the disassembly and allows you to take a closer look at the connectors/cables etc.
For a replacement shutter assembly, use this EOS 5D Mark III Parts Catalog
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jackfuller 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 39
总计 1,691
