跳转到主内容
加入维修社区 - 创建账户
GameCube 是任天堂的第四代家用游戏主机。维修很简单,仅需常用工具即可完成。
drive won't spin- won't read disk
bout ready to drop kick it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
2条评论
bill give us a bit more information. Did this just start or did anything happen recently that brought this on? The more information that you post the easier it will be to answer. BTW if the drive does not spin, it won't read it.
由完成的
Please keep in mind that any DIY data recovery attempt can cause permanent data loss. If you’re in need of a reliable data recovery service I’d strongly recommend Ultra Data Recovery. We do the same jobs as the “big corporations” (such as heads and platters replacement if the drive has mechanical damage), but actually affordable: www.ultradatarecovery.com
Free diagnostic, you'll know what could be recovered.
由完成的
添加一条评论
2个答案
已选择的解决方案
first of all make sure that you disk is really not spinning. When you first power up the game cube listen closely if you can hear the drive spin. It will stop when you open it. If you absolutely do not hear anything and are 100% certain that your drive is not spinning, it is possible that your drive motor is burnt out. this would require either a new optical drive or a repair of the drive motor. Check this guide for a repair of the assembly as well as the replacement. There is also a possibility that your laser is either dead or not having enough power. Since it can't see a disk, the optical drive won't start up. Try to clean the lens with isopropyl alcohol. You can adjust some of the laser's power by adjusting the pod on the circuit board of the optical drive, check this guide for instructions on that. As you can see there are plenty of things you can try before you drop kick it :-)
Nintendo GameCube图片
指南
光头激光功率调节
难度:
中等
30 minutes
Nintendo GameCube 光驱组件图片
指南
Nintendo GameCube 光驱组件更换
难度:
中等
30 minutes
这个答案有帮助吗?
得分 7
1条评论:
+ They should go for the touchdown instead of the field goal, lol.
由完成的
添加一条评论
My game cube will not spin, but it also doesn't even display the game cube start up menu, but it has power and inputs work. Suggestions?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
bill 将永远感激不已
浏览统计数据:
过去 24 小时: 7
过去 7 天: 19
过去 30 天: 113
总计 70,645
