跳转到主内容
加入维修社区 - 创建账户
型号A1367,闪存容量:8、16、32及64GB
Why is there a box around everything I click?
Every time I click something, a black box pops up around it and it is very anoying.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 42
15条评论
It won't work
完成的
Its Driving me FRIGGIN LOOH LAAAH!!!!! Trying to fix it for 2 hours now, had problem also with someone constantly reading text and app covers on home screen non stop over 50+ Apps, reading them @ 90mph lol. Now just left with this stupid box!!! I have actually changed so many settings by accident on the phone cos the box has a mind of its own bouncing all over the screen, that if I do fix it , I wont know What's what n b like F*** where is everythin ????
完成的
Thank you! I went to General, then to accessibility and last to "Voice Over". Turn off and turn back on... This is how I fixed the annoying blue box and clicks. Thanks for the tip.
完成的
i have this problem too! i turned it off, and turned it back on. now it won't let me put in the password. help!
完成的
Well i cant actually get into my phone because its on activation lock and i know my apple id email but i dont know the password so whenever i go to reset it i cant because it ask for the old phone number of that phone but i dont know it.
完成的
显示更多的10条评论
添加一条评论
7个答案
已选择的解决方案
Sara, it sounds to me like you have your Voiceover on "When an item on the screen is selected, a black rectangle called the VoiceOver Cursor appears around it. The VoiceOver Cursor is displayed for the benefit of sighted users with whom you may be sharing your iPod touch. " Turn VoiceOver on or off: Go to Settings > General > Accessibility > VoiceOver. Download the manual from here starting on page 119 it will tell you all about it. Hope this helps, good luck
这个答案有帮助吗?
得分 24
26条评论:
I REALLY HOPE this works. I have the same problem, thanks in adavance
完成的
OT, could this be the answer to this question? Has artifacts attached to the desktop icons and mouse pointer..
完成的
I can't scroll tho
完成的
I can't scroll down
完成的
thanks very much ey...it worked on my Ipad
完成的
显示更多的21条评论
添加一条评论
最有帮助的答案
Hit the home button 3 times... it will work!
这个答案有帮助吗?
得分 31
16条评论:
perfect! thanks
完成的
thx very very mutch
完成的
Thank you so much for the help
完成的
Worked straight away - thanks for your help :)
完成的
thank you so much!!!!!
完成的
显示更多的11条评论
添加一条评论
Ask Siri to turn off voice over. It worked for me.
这个答案有帮助吗?
得分 5
9条评论:
I have iPhone 4 I phone 4 doesn't have sir
or does it
I dunno
完成的
I meant siri
完成的
my siri is not listening very well
what do I do now!!!!!!??????!!!??!?????
完成的
Sir I is not responding
完成的
I have an iPhone x. This worked. Say, "Hey Siri" then "Go to Voice Over". You'll be able to turn it off even if your screen doesn't allow you to by saying "Turn Off Voice Over". Immediately able to touch my screen again without the glitches or annoying boxes surrounding every little thing on the screen that I touch. You can try double tapping the item but mine didn't always work.
完成的
显示更多的4条评论
添加一条评论
Hold your home but ten for three long holds
这个答案有帮助吗?
得分 3
3条评论:
what home grace
完成的
I found my pld ipod mini. Hiw do i fix that?
完成的
Not sure but try holding home button and on off bottom at the same time for 30 second
完成的
添加一条评论
Like the other answers, pressing the home button thrice worked! My friend lent me his iPad and I let my cousin play the iPad. After, she left it on the drawer. I checked it and it does not work! It illuminates the screen but nothing shows up. But then I saw an answer that said to tap the screen with three fingers and it turned on "'BUT"' whenever I tap anything it squares the tapped thing. So the technique worked! I am thankful to the others who helped me since it saved me from getting grounded "'AND"' getting fined as well.
这个答案有帮助吗?
得分 0
2条评论:
It just keep asking for password code for siri but when I type a code it doesn't work
完成的
Hmm thrice!
Juliet is the sun.
Arise fair sun and kill the envious moon
完成的
添加一条评论
Just hold down button for Siri and say, "Siri, turn off "Voice over in settings". My phone was instantly restored and back to normal.
这个答案有帮助吗?
得分 0
1条评论:
Worked on the first try with Siri assist.
完成的
添加一条评论
I have an LG and it has a voice to it and there a green box over when I hit everthing and it wont let me swipe. or nothing how do I make it go away????
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sara 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 48
总计 168,092
