跳转到主内容
Repair and disassembly guides for Sony DVD players.
DVD and CD Disk not reading
Ive got a CD/DVD/3D Blue ray player that wont recognize a disk (tried CD and DVD's). I have it all apart and cleaned the reader with a q-tip (aka Fleece Crested Scepter of Q-Teep). The laser dose turn on (I see it turn purple yes I know don't burn my eyes out) and the head moves back and forth. My big questions is should the disk be spinning when its checking for a disk? The motor dose spin free by hand but the disk doesn't spin when it checking for a disk. A lot of guides mention turning some potentiometer to adjust the laser power; I cant find any on this model.
Update (05/10/2022)
The model number is HBD-N760W
Here are some pictures to help
https://imgur.com/a/OFJ7Ek0
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @scootergarrett,
What is the model number of the player?
The disc should be spinning or at least it should have rotated because the player is looking for the TOC (table of contents) located on the disc.
This applies to CDs and DVDs. With DVD it is slightly different but it still requires the disc to turn. This link describes it better than I can
这个答案有帮助吗?
得分 1
2条评论:
@scootergarrett download the service manual from here Section one will have a lot of the information you may need fo the repair. I am certain your optical drive controller uses trim pods but we would have to see the boards etc. to determine this. Careful with messing with those because a wrong adjustment can burn out the LASER diode.
完成的
Thanks for the user manual, I still cant find the potentiometers, on the board or the circuit diagram. everything else that needs to move seems to move correctly.
https://imgur.com/a/6MPcJXb
Starting to think its not going to happen.
完成的
添加一条评论
添加你的答案
Garrett Cassidy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 12
总计 341
