跳转到主内容
Released October 2, 2001, identified by model number DVP-FX810
Line in won’t work
Line in won’t work with my thing
(Wii av port)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Logan Lamothe your "thing" being a DVP-FX810? Sounds like you are trying to connect a WII to it. Is that correct? What happens when you try?
完成的
No picture appears and it still says line in
完成的
添加一条评论
1个答案
Logan Lamothe follow the instructions in your manual. If you do not have one, you can download it at places like this
You need to check/set the side switch LINE SELECT IN OUT and see if that changes anything. Of course you also have to make sure that your AUX cable is compatible. Double check the manual for all of this.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Logan Lamothe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 194
