跳转到主内容
加入维修社区 - 创建账户
索尼α6500(型号为ILCE-6500)是一款采用APS-C画幅传感器的无反光镜数码相机,配备E卡口,这是索尼第一款带有五轴防抖的无反光镜数码相机。 索尼α6500于2016年11月正式发布。
Main board swap - how to avoid problems?
I’ve got Sony with a power problem. After investigation I found it has an essential chip (IC5700) killed by a dummy battery. It can’t be replaced, so I have to do a whole main board swap.
It’s (insanely) pricey, but possible. The problem is - many report that after a replacement camera may malfunction: EVF may stop working, AF problems, some functions get disabled. As it’s costly thing to do I’m very nervous - how to guarantee myself from such things?
Service manual describes how to transfer needed data from an old board, but:
Old board must work (which it doesn’t want to do);
You need Sony Adjust Station software (which isn’t available).
And I have some suspicious thoughts on that…
What should I do to get this cam working again? What’s your experience?
Update (03/27/2022)
UPD. Board photos if needed
Can’t say if it’s useful though
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
I think that you cuold look for the service manual, check where is the ic that connects the DC to DC converter and rplace one whith the other, or at least see what is wrong checking voltages
由完成的
添加一条评论
1个答案
@intenditore anytime you are running into boards that need proprietary software installed which this (Old board must work (which it doesn’t want to do); You need Sony Adjust Station software (which isn’t available) eludes to, I would recommend to use a authorized service center. I recorgnize that this is additional cost etc. but I have had to many boards/devices rendered useless, by not having access to the right setup. .
这个答案有帮助吗?
得分 0
3条评论:
I might consider this route, but old board is inoperable, reading data off of it wouldn't be possible. Would service help here anyhow? I doubt.
And the price they'll ask is going to be close to a nice used device I guess
由完成的
@intenditore I understand. The only other thing to do is to change the board and hope for the best. Maybe we can try and find the software that you’ll need for the adjustments and I wonder if the board has an EEPROM IC which information may be needed. Not sure if you already pulled the board. If so, post some really good clear pictures of it with your question. Maybe we can identify something that may help
由完成的
@oldturkey03 sorry, next day after your answer my father had an attack, I had too differernt questions to answer. Updated the post with photos
由完成的
添加一条评论
添加你的答案
Anri 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 53
总计 1,780
