跳转到主内容
加入维修社区 - 创建账户
型号为 GL503VM-B17N13 的 Asus Republic of Gamers Strix 15.6 英寸游戏笔记本电脑的维修与故障排除指南。
Guide for re-pasting and cleaning
Hello,
I bought my Asus ROG GL503GE back on November, 2018. Since the last couple of days, the left CPU fan is making a faint buzzing sound, and the temps aren’t that great as those were before. I am thinking of cleaning and re-pasting my laptop. I am planning to use Noctua NT H1 for repasting.
So here are the questions:
1) Should I use isopropyl alcohol to rub off the old thermal compound? I heard some say that using alcohol might damage CPU linings (don’t know what they mean).
2) After disassembling the laptop and removing the power connector, is it a good idea to press the power button to drain the leftover charge from the capacitors inside?
3) Which order should I remove the screws from the heatsink? Are there any numberings on the screws?
I haven’t messed around with disassembling laptops that much. I would like to know the proper guide to remove various connectors inside the laptop. If there is any good thread/video about that, please share :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Anwarul Bashir Shuaib use this guide for the thermal paste 如何涂散热膏 I would definitely perform a discharge you listed with 2. You will be okay with pretty much going in any order to remove those screws.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anwarul Bashir Shuaib 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 662
