跳转到主内容
The HP Compaq 6730b is the "business" edition of the 6730 laptop line released by HP.
Stuck on starting windows screen
Hi my laptop is stuck on starting windows screen really slow to start up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
How slow is it? Is the OS installed on a hard drive or solid state drive?
完成的
添加一条评论
1个答案
Factory Reset:
You could try to do a factory reset on the computer (you can find it in settings and lookup factory reset) but before you do make sure that you backup all of your important files/files you would want to keep(Photos, Documents, etc.) because it will delete All of your files
Upgrading to an SSD:
If your computer has a hard drive, you could try to upgrade it to an SSD which will make loading times much faster but also make sure to backup and/or transfer your files to the SSD
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 240
