Stuck on starting windows screen
Hi my laptop is stuck on starting windows screen really slow to start up
Factory Reset:
You could try to do a factory reset on the computer (you can find it in settings and lookup factory reset) but before you do make sure that you backup all of your important files/files you would want to keep(Photos, Documents, etc.) because it will delete All of your files
Upgrading to an SSD:
If your computer has a hard drive, you could try to upgrade it to an SSD which will make loading times much faster but also make sure to backup and/or transfer your files to the SSD
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 461
How slow is it? Is the OS installed on a hard drive or solid state drive?
由 Andrew S 完成的
