跳转到主内容
The HP Compaq 6730b is the "business" edition of the 6730 laptop line released by HP.
5 个问题 查看全部
Stuck on starting windows screen
Hi my laptop is stuck on starting windows screen really slow to start up
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
How slow is it? Is the OS installed on a hard drive or solid state drive?
完成的
添加一条评论
1个答案
Factory Reset:
You could try to do a factory reset on the computer (you can find it in settings and lookup factory reset) but before you do make sure that you backup all of your important files/files you would want to keep(Photos, Documents, etc.) because it will delete All of your files
Upgrading to an SSD:
If your computer has a hard drive, you could try to upgrade it to an SSD which will make loading times much faster but also make sure to backup and/or transfer your files to the SSD
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
John James 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 233
