跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
Post-battery replacement, battery unglued / unstuck
I performed a battery replacement with the iFixit repair kit. The battery works well, but the adhesive of one of the cells didn’t hold, and the battery is now rattling around inside my case.
Oops…
What should I do to fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
Same here. IFixIt sent me some kind of duct tape which i used but quickly to no avail.
完成的
添加一条评论
1个答案
最有帮助的答案
@mishchea some doublesided tape like this Tesa 61395 Tape or others that fit, strategically placed should be sufficient to hold it in place. Lots of room would lead me to some velcro which will make the next battery replacement easier :-)
Custom cut rolls of Tesa 61395 double-sided tape for repair.图片
产品
Tesa 61395 Tape
$5.99
这个答案有帮助吗?
得分 3
2条评论:
Thanks for the suggestion -- what width would you recommend for the tape? 8mm? 4mm?
完成的
@mishchea you got lots of room. Go for the 8mm
完成的
添加一条评论
添加你的答案
Andrey Mishchenko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 280
