跳转到主内容
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
20 个问题 查看全部
early 2013 MacBook Pro 15 inch
Model A1398 15 inch early 2013 macbook . I have a cracked screen. What screens will work for this? Or is there a way to make a screen compatible with soldering or changing components.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Big Phil The Piper  you’ll need Apple part number 661-7171. This is a beast to change that the display. I suggest you replace the complete assembly. ''MacBook Pro 15" Retina Display Early 2013 Display Assembly Replacement
Now could you make another screen fit. Possible but you would need to have the datasheet for your screen and then compare it to the datasheet of other ones. not an easy task to a. find it and b. possibly convert it to meet the requirements. It would most likely cost you more than the complete assembly.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Big Phil The Piper 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 63
