跳转到主内容
Risk of battery fire after logic board spark
I've had this MacBook pro since 2013 and in 2015 juice was spilled on it and it no longer worked. Now, 5 years later I decided to take a look at the laptop and see if I could clean it up and fix it. I took it apart, cleaned it with alcohol, and reassembled it. I powered it on and it worked for a couple of minutes, the batteries charged to 12%, but then it shut down. I tried to power it back on but the backlight kept coming on and off and no boot. I went to disconnect the battery from the logic board but when my screwdriver touched the screw on the connector it sparked. Fearing that the batteries may catch fire I put it outside for now. Does anyone know the likelyhood that the batteries may catch fire. Keeping in mind the batteries have been sitting for about 5 years.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Unless the battery has been punctured or has swollen there is little risk of fire. Next time use your fingernail or a sponger.
这个答案有帮助吗?
得分 1
添加一条评论
The OEM batteries are pretty good when it comes to sparks, worse case scenario you damaged the logic board or, believe it or not, there’s a circuit board in the battery. Liquid damage should’ve been addressed immediately. You might have luck sending it to Louis Rossman for data recovery at least.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alexander Vlasopoulos 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 192
