跳转到主内容
苹果2016年对于专业用户的笔记本更新。具有15英寸,2880*1800的Retina显示器, 四核心 Intel Core i7处理器, 256 / 512 GB /1 TB / 2TB 存储空间, 16 GB 内存, 和一个带有Touch Bar的键盘。2016年11月发布,型号为 A1707。
244 个问题 查看全部
Screen shuts off after opening more then ~30 degrees
This began with dimmer nodes at the bottom of the screen as it was opened and concluded later with the screen first going dimmer and then blacking out as it is opened before this issue was fixed by resetting the pram and smc. However that is no longer the case, additionally, it has been taken to a repair place and they said that the cable seemed fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I have a MacBook Pro 15 mid 2017! He was having problems with the keyboard! Slightly elevated trackpad, back cover buckling with the battery puffed up, the screen only worked if it opened approximately 75 ° and the screen did not close completely!
My Mac was eligible for the keyboard recall program! They changed the top case and the battery! But they didn't change or repair the display / screen! They are claiming that the screen problem was caused by dirt debris that damaged the cable! What cable are you using on newer devices? Because I have another MacBook Pro 13 mid 2010, which works perfectly today, it is used in the same environment, same residence!
Is it the battery that did not cause this problem on the screen? Until the screen didn't close completely! Hidden cable manufacturing addiction? How can dirt cause such damage in 2 years and not in 10 years?
完成的
添加一条评论
3个答案
已选择的解决方案
You have the dreaded FlexGate issue! Ouch!
Here’s more on the issue The Design Flaw Behind MacBook Pro’s “Stage Light” Effect and 2018 MacBook Pros Try to Solve Flexgate Without Admitting It Exists
Sadly Apple only offered a extended warranty for the 13” models 13-inch MacBook Pro Display Backlight Service Program
You’ll need to visit a real Apple Store and request a warranty exception. Be polite! And if they don’t give it to you, ask to speak to the service manager, and work your way up the food chain.
If you can’t get to an Apple Store your only option is replacing the display your self which is not that hard! Here’s the needed part: MacBook Pro 15" Retina (Late 2016-2017) Display Assembly and here’s the guide 2016 年带 Touch Bar 的15寸 MacBook Pro 屏幕更换
MacBook Pro 15" Retina (Late 2016-2017) Display Assembly图片
产品
$549.99
这个答案有帮助吗?
得分 4
2条评论:
@danj I got the same machine in, it's the same problem, of the screen shutting down after opening greater than 30 degrees but no stagelight issues. A visual inspection is showing nothing amiss. Runs fine till opened greater than 30%, then the display just goes black. Just in case, I reset the SMC and PRAM. Any pregnant ideas?
完成的
@mayer - Using a flashlight do you see an image at all?
完成的
添加一条评论
Did u guys figure out how to fix this issue? I’m having exactly the same problem.
这个答案有帮助吗?
得分 0
添加一条评论
Same issue 13 inch MacBook pro retina display 2016-2017 it was working when fully opened for awhile then went back to only working at 30 degrees opened. Also stage light issues.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Samuel Aplin 将永远感激不已
浏览统计数据:
过去 24 小时: 15
过去 7 天: 106
过去 30 天: 533
总计 11,620
