Why is my Soundfreaq sound kick not charging?
After long frequent use, the speaker no longer charging and power light not turning on, cord fits loosely. I opened up and no apparent damage. Suggestions?
@ilovelucy24680 check the charging port for power when you have the charger plugged in. It is possible that the port simply wore out. To replace it you would need to measure it etc. and use that information to try and match one with some ports available at mouser.com or digikey.com. Also, replace the battery while you are at it. Use this teardown to get into it. Use this 在已经存在的问题里加入图片 to add your images if you need further help, with your QUESTION.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 15
总计 1,813
