跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
20 个问题 查看全部
replace battery charging port
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
Ralph Cross if you are talking about the lightning port, check this guide iPad 5 Wi-Fi Logic Board Replacement step 88 and others
这个答案有帮助吗?
得分 2
添加一条评论
I am not sure what you are asking, but if you are wondering what part you should replace should be easy, use an amp reader to see if the motherboard is pulling any power from the charge port if it's not then its a port replacement if it is then its a battery replacement.
这个答案有帮助吗?
得分 0
1条评论:
How do I do this?
完成的
添加一条评论
添加你的答案
Ralph Cross 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 635
